Author Topic: Blinkers/Flashers/Turn Signals  (Read 1514 times)
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« on: May 13, 2009, 04:32:26 AM »
If my blinkers are lighting up, but not flashing, do I just need a Blinkers/Flashers/Turn Signal relay?
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline Steve F
Re: Blinkers/Flashers/Turn Signals
« Reply #1 on: May 13, 2009, 04:44:52 AM »
YEP.
Offline Bill Vaughan
« Reply #2 on: May 13, 2009, 04:54:02 AM »
Honda part # 38301-KJ6-743
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline cb750fbomb
  • is by no means a
« Reply #3 on: May 13, 2009, 05:16:37 AM »
Great. Thanks guys :)
Almost forgot. Is there a inexpensive way to go about getting one of these or do you have to buy a Honda one? I just lost my job, as of Friday, and need to cut any corners I can.
« Last Edit: May 13, 2009, 06:42:17 AM by cb750fbomb »
'77 CB750F2
Offline jmckinne
  • K4 CB750, Naked 76 GL 1000
    • Family site
« Reply #4 on: May 13, 2009, 09:03:58 AM »
Sorry to hear, tough times.
You can use any auto store 12 volt flasher unit as long as the pin count matches the stock. A digital one needs less current to do it's job too.
The flasher unit is not the only possible explanation though. If overall current is low the stock one will not "flash". That could mean a bad bulb, battery, or a short somewhere else.
1) Does it flash when RPMS are high, just not when idling? Not the flasher then.
2) Check all your bulbs. A break in the circuit is designed to stop the flasher as a fault indicator in some systems.
3) What does a voltmeter say when placed across your battery terminals?
Flasher's are pretty simple items. Sometimes they go bad - and they are cheap - but sadly it's often something else that's wrong.
Offline mark
« Reply #5 on: May 13, 2009, 09:18:53 AM »
go out to the junkyard and poke through the old pickups with big trailer hitches on......
there should be a nice 2-prong electronic flasher in one of 'em.
tell a sad story or a good joke and you might get it as a freebie.
F you mark...... F you.
Offline cb750fbomb
  • is by no means a
« Reply #6 on: May 13, 2009, 03:54:17 PM »
1) No. It only brightens and never flashes
2)K
3)It's operating as it should. My charging system is fine.
'77 CB750F2
Offline cb750fbomb
  • is by no means a
« Reply #7 on: May 13, 2009, 03:59:30 PM »
Does it have 2 or 3 prongs?
'77 CB750F2
Offline Steve F
« Reply #8 on: May 13, 2009, 04:59:50 PM »
Go with the electronic flashers since they're more reliable no matter what the voltage is at (above 9 volts usually), and they have typically 3 prongs: 1 for the load, one for the ground (-) green wire and one for the incoming supply.
