Author Topic: Need an opinion, electrical support for everyone?  (Read 1169 times)
« on: May 21, 2009, 07:21:39 AM »
I've been refurbishing some voltage regulators for the Hondaman Specials, using old used parts. After all the years, the contacts and spring forces have changed quite a bit, but I am finding that I can realign them and get the original (or better) performance from them again. And, I can tune them for the new AGM batteries, which is a nice feature!
So, is there any interest here in either a "service" to your old regulator, or maybe an "exchange" of a cleaned, adjusted, and tuned-to-your-battery regulator for your old one?
The part that is unobtainable now is the unique 3-tap resistor on the back of these units. This can be replaced, in a pinch, with two separate resistors. This which doesn't turn out too badly, just looks a little different, works fine. Most are OK, but some have become cracked over the years, or just electrically open. This makes for poor battery life and low voltage (assuming other equipment is still stock, of course).
Here's what it would entail:
1. I clean and inspect the unit for anything that would stop it from being "refurbished".
2. If adequate, I can clean, reshape, and polish the contacts inside (i have the proper relay repair files and polishers for this work).
3. I connect it to my variable-voltage power supply and adjust the spring tension of the relay contact to get the voltage performance that was originally intended.
There are essentially 2 types of regulators on these bikes: the On-Off types for the field coil, which resemble the old Ford electro-mechanical voltage regulators, and the Hi-Mid-Lo types of the later design. They set up a little differently.
I'm estimating the cost would be about $20 if the resistor is OK, and around $30 if the resistor has to be replaced with 2 new ones.
If it seems worth it to enough riders, I'll post it in the For Sale section.
(Now, back to sprockets...  :) ).
Offline OldSchool_IsCool
  • Really feeling like an
Re: Need an opinion, electrical support for everyone?
« Reply #1 on: May 21, 2009, 08:01:27 AM »
Hey Mark,
I'm interested in having my regulator refurbished ( '77 550K) but not until winter.  If you opt for the exchange method, maybe yet this summer.  I'm not sure how well the exchange method would work for you as you could get back a POS after you just sent out a no doubt top quality rebuild.
At any rate. put me down as interested.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Old Scrambler
« Reply #2 on: May 21, 2009, 09:20:33 AM »
I think this is a wonderful service, especially for newbies and owner's complaining about short battery life.  I have a local shop that tunes my regulators for about the same fee.  Go for it!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline GammaFlat
« Reply #3 on: May 22, 2009, 03:55:53 PM »
Count me in for one.
K6
85 Goldwing
