Author Topic: Loss of power and stalling after riding for 20 minutes?  (Read 1140 times)
deanoevans
« on: May 28, 2009, 12:22:26 PM »
I'm somewhat of a noob here. Forgive my ignorance.
I have a '73 CB350F.  It runs great for about 20 minutes. Then it begins to stall when idling, and I loose power when accelerating. It it us feels different. It gets worse the longer the ride. Then when I let it sit for 30 minutes it runs good again.
I just installed a new clean gas tank. Fuel appears to be flowing nicely from the petcock.
Any suggestions would be greatly appreciated.
Offline Johnie
Re: Loss of power and stalling after riding for 20 minutes?
« Reply #1 on: May 28, 2009, 12:38:48 PM »
Once this happens again open the gas cap.  If it works good then your gas cap vent may be plugged.  If that is plugged it will create a vacuum in the tank and not let gas flow good.  At least you can eliminate that item if it still does not work.  Once you know we can move on from there.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Johnny5
    • CB350F build thread
« Reply #2 on: May 28, 2009, 12:40:11 PM »
Are your floats set correctly?
Also, what shape are your coils in? Good spark?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline heyjones
« Reply #3 on: May 28, 2009, 03:15:48 PM »
I had this same issue on my 750, turns out it was a loose connection to the stator. So sometimes I could ride for hours no problem, and others I'd get 5 miles down the road and stall out. Then if I let it sit for a while, the battery would "recharge" itself and I could get going again. But if it stalls and you still have power, then nevermind.
1976 CB750K
My Build Thread
Offline Hush
« Reply #4 on: May 28, 2009, 03:30:35 PM »
Could be coils going bad, they sometimes fail as they heat up then once cool again fire up OK so testing has to be done when bike is hot.
Otherwise could be a charging issue........get back to me if it looks like that......Hush.
gilesclement
« Reply #5 on: May 29, 2009, 10:38:40 AM »
I've just gotten over similar symptoms, on mine it was the pulse generators failing once hot. Not sure if yours has those or a points setup but if you do have a electronic ignition you can check the resistance on them. Could also be coils.
Offline Philly550K1
« Reply #6 on: May 29, 2009, 02:15:31 PM »
might also be rich. does it need choke to start? does adding choke during the first few minutes create the same symptoms?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: May 29, 2009, 02:21:02 PM »
Is your bike stock? (original airbox, jets, pipes, points, coils?).
