Author Topic: My CB750a only runs well with the choke on. Ideas?  (Read 3405 times)
Hambone
« on: June 07, 2009, 06:57:44 AM »
My 1977 CB750a only runs well when I pull out on the choke. It runs rough and stalls when I release it. It is an automatic model, does that sound like the accelerator pump diaphram? The carbs are super clean, I just need to find out where to start.
Offline CB500_k2
  • Wrenching makes a good retirement.
Re: My CB750a only runs well with the choke on. Ideas?
« Reply #1 on: June 07, 2009, 07:11:19 AM »
I had the same problem with my CB500 when I was bringing her back to life.  I had completely cleaned the carbs, compression was good, ignition timing perfect but it would only run with the choke engaged.  After much exasperation and multiple carb removals I raised the fuel levels in the carbs by raising float height and she has run perfectly ever since.  I measured the actual liquid level with a plastic tube connected to a modified drain screw.  I set the level 2 mm below the gasket.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 07, 2009, 08:40:18 AM »
Is the air filter installed?
Offline Spanner 1
« Reply #3 on: June 07, 2009, 10:42:52 AM »
The carbs on the A are very dependent on the acc. pump at anything above idle...the squirt of fuel increases the rpm enough for the main-jet to take over..blah, blah...!
the 'pump' circuit does not effect idle tho', so i'd be looking at float level ( as previous post) and low speed jets, did you pull 'em out and clean them and flush their air passage from the carb throat ?
Hambone
« Reply #4 on: June 07, 2009, 06:50:27 PM »
Thanks! I'll get them off. and check the float levels. I have only had the bike a couple of days but I need to get this worked out.
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #5 on: June 07, 2009, 06:59:05 PM »
Is the tank clean? I had my carbs off a lot without realizing that the sh!t in my tank was clogging my jets up.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Hambone
« Reply #6 on: June 15, 2009, 04:45:39 PM »
Thanks for the help guys!
