Author Topic: Which carb kit ?  (Read 4429 times)
BlackHog
Which carb kit ?
« on: June 08, 2009, 02:39:40 PM »
Hello everyone. I'm new to the forum and have a carb question.       I recently bought a '76 CB750 and looking at carb rebuild kits but just not sure which kit to get.
Also think carbs came off newer cb750.
Serial no on carbs is PD41BA
Can anybody tell me what is the difference between keyster carb kits KH-0983N and KH-0982N? And which one will fit my carbs?
Thanks for any help.
Michael
Offline wick
  • cb750k2 836
Re: Which carb kit ?
« Reply #1 on: December 22, 2010, 08:43:10 AM »
 ???-- did u ever find- out-- peeps r telling me to stay` away-- from-- keyster???
so what -- carb rebuild kit is good..?
thnx////
Offline greenjeans
  • 1972 CB750K2
« Reply #2 on: December 22, 2010, 09:58:25 AM »
My 2cents...   You probably only need gaskets.   The jets and needles are brass and unless someone has buggered them up with drill bits etc they don't really wear out.
Just clean the crap out of them.   I've always heard that the Honda gaskets, jets and needles are of a better quality.
I have tried both.  The gaskets that came with the Keyster kit started leaking less than a year after purchase.  Now, I will say that I had the bowls off a few times
to get the needle position correct - not sure if that contributed to their early demise.  I have Honda gaskets on there now.
« Reply #3 on: December 22, 2010, 10:04:59 AM »
YES!!!!!
..and the little o-rings if ya got press-in jets.
(the word is keyster jet ID and needle tapers are slightly different than OEM HONDA)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: December 22, 2010, 10:28:25 AM »
(.. and needle tapers are slightly different than OEM HONDA)
That's what I found. A member here tipped me off to a trick (kghost?). I used a drill bit gauge and found the holes into which the needles would fit, but not fall through and checked how far down the needles went before binding on the gauge hole. Big difference. As I recall, the Keyster needles were much more slender and slipped further down. Can't address the jet ID issue though.
Offline wick
  • cb750k2 836
« Reply #5 on: December 22, 2010, 11:51:40 AM »
ok thanks.... so if i want- oem- honda -  keihin     need- to hit dealer ext.   who makes- k&l.. i need new needles ext. brass worn- good.---
Offline SOHC Digger
  • I'm not an
« Reply #6 on: December 22, 2010, 01:20:20 PM »
These are not the kits for the PD carbs!  You will need the kits for the 77-78 CB750's!  The best place right now (until parts-n-more get back up) is www.vintagecb750.com and I would strongly recommend getting the four rebuild kits AND the accelerator pump.
Offline greenjeans
  • 1972 CB750K2
« Reply #7 on: January 24, 2011, 01:37:21 PM »
So....   K&L vs Keyster    anybody want to sound off on that fight ?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #8 on: January 24, 2011, 02:35:48 PM »
I have used Keyster and K&L kits and bpth have worked fine on my bikes.
I didn't use the Keyster needles on my K3 carbs though, I had problems trying to get the needles off and left them on.
Needles pretty much never wear out unless you bend or break them anyway.
Offline Jaydem
« Reply #9 on: January 24, 2011, 04:45:53 PM »
I recently used Keyster and was very happy with the quality
1974 Honda CB 750 (Restoration/Cafe Project)
Offline BAchvytrk
« Reply #10 on: January 25, 2011, 11:43:01 AM »
i use k&l kits all the time and have never had a problem. probably rebuilt over 30 sets of carbs using their kits, never had an issue
71 FLH
74 Ironhead
1965 305
1971 SL350
1974 750k
1975 550F
1977 550K
1980 KZ440
1980 CB900F
