Author Topic: 350Four Key Switch Bracket?  (Read 1063 times)
Offline 736cc
« on: June 11, 2009, 03:52:27 AM »
My rcent 350Four find has a relocated key switch (to the handlebars). Whhat does the orig bracket look like and where does it mount? Is it same as a 350 twin mounting? Does it go oppositte of the horn using same screws? Pic appreciated. Thx in advance.
Offline HondanutRider
Re: 350Four Key Switch Bracket?
« Reply #1 on: June 11, 2009, 05:51:45 AM »
You are correct - this bracket mounts on the other side of the horn using the same mounting bolts as the horn.
Here's a picture of my bracket that I took while it was removed for painting.  Hope this gives you an idea of the part you need.
