Author Topic: Leper Messiah- '78 CB750k Street Tracker  (Read 18102 times)
Offline Joksa
Re: Leper Messiah- '78 CB750k Street Tracker
« Reply #25 on: October 20, 2009, 07:06:04 AM »
Can you at least put 1 dirt track piece on it ?
Isn't form mainly following function in racing?
E.g. this kawasaki http://thekneeslider.com/archives/2007/11/30/kawasaki-ninja-flat-tracker/
doesn't have so called dirt track tail piece, but still it is quite competitive
or this similar short tracker kawasaki has even original forks:
and so called motocross bars. Still it seems to perform on a short track.
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« Reply #26 on: February 18, 2011, 01:41:24 PM »
I guess I should update. I went with k70's and love the way it rides. I'm still considering hooping the rear and building a seat to match, but that's it for now:
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline desert rat racer
« Reply #27 on: February 18, 2011, 02:37:44 PM »
I like what you've done so far! Rear drum brake? Sweet! Do the drum breakes have performance troubles when they are wet or hot?
I heard they dont work well in those two situations, could be one of those "I heard it from a guy, who heard it from a guy....." things where they just spew what someone else said without any REAL test. Dispell or confirm please!
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #28 on: February 21, 2011, 09:21:56 AM »
I've only had one issue with drum in the two years I've had it and it was due to some jerry riggin on the PO's part (weird drilled brake arm snapped and caused brake failure. Does well in the rain and heat. I haven't gotten it terrible muddy to see how that goes though.
« Reply #29 on: February 22, 2011, 11:00:24 PM »
I just bought a KZ400SE (oops honda site?!) it has front and rear drums. Thanks for dispelling the myth!
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #30 on: June 06, 2012, 06:57:48 AM »
Finally had the rear hoop welded in, the cross hoop cutout, and rear fender remounted
The seat is made out of a Maple grommet board, the padding from the old seat, and the vinyl from the old seat (66 Buick Riviera seat material). Next up will probably be top end gasket replacement as I have leak at the right head. This pisses me off, as I have already had the gaskets replaced 2 years ago. =(
