Author Topic: powdercoating comstars gone wrong. Im an idiot.  (Read 2082 times)
Offline Flying J
« on: July 15, 2009, 04:49:13 PM »
i didnt take the bearings out of the wheel before i powder coated it because i figured it would protect the threads and the bearing surface. But what it did was make a mess on top of the bearing retaining ring and now i cant get it off. Any ideas are welcome. Im going to try heat and a wire wheel. I hope i dont ruin it. Is the front a reverse thread or standard?
Offline Patrick
Re: powdercoating comstars gone wrong. Im an idiot.
« Reply #1 on: July 15, 2009, 05:10:42 PM »
Aircraft paint stripper, which you can buy at Walmart or Home Depot, melts powder coat.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: July 15, 2009, 05:37:35 PM »
its standard thread, and try a wire wheel on a dremel, they're tiny and more detailed.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: July 15, 2009, 06:08:34 PM »
I'd cut it out at this point.  Drill most of the way through the retainer carefully in two or three places, using a bit that just smaller than the retainer is thick.  Then use a chisel to remove the retainer in chunks.  If you're careful you can avoid dinging the threads.
mystic_1
- John Augustus Shedd
Offline Flying J
« Reply #4 on: July 15, 2009, 06:36:44 PM »
Got it!!
I used the aircraftstripper and a propane torch along with my makeshift tool. Sombody realy should make a socket and sell it for this purpose.
Thanks for the fast help.
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: July 15, 2009, 09:13:40 PM »
awesome
rzmike
« Reply #6 on: July 16, 2009, 12:04:45 PM »
Not sure what size you would need, but here are some retainer removal sockets. Also work on wp fork caps and hyundai brake caliper pistons.
http://www.motionpro.com/motorcycle/tools/category/bearing_retainer_removal_and_installation_tools/
This is an awsome tool for removing the bearings
http://www.motionpro.com/motorcycle/partno/08-0269/
Mike
Offline Flying J
« Reply #7 on: July 16, 2009, 12:25:18 PM »
This is what i used to get the bearings out. Worked great.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95987
Offline IainC
« Reply #8 on: July 16, 2009, 03:22:06 PM »
Got some pictures of the whole wheels now that they are powdercoated?
Offline Flying J
« Reply #9 on: July 16, 2009, 03:44:59 PM »
Ill post some when i get them on the bike. Right now i only have the front one done. I had a spare front so i had it done when i did my 550 rims. Here are a few pics by my 550. I was thinking about putting comstars on it.
here is my makeshift bearing retainer tool. You can see the rear bearing is not coming out as it bent the 2 screws and it still hasnt budged. Im going to try drilling the holes deeper.
Offline jtb
  • An unlikely
« Reply #10 on: July 16, 2009, 07:00:34 PM »
Damn, that's almost the same reainer tool I've got.  Use shorter screws.
1977 CB750F
1985 V65 Sabre
Offline mystic_1
  • 1970 CB750K
« Reply #11 on: July 16, 2009, 07:47:14 PM »
The small holes you drilled to remove the punch marks, yes?  two or three threads worth of depth should do it, say around 1/8 to 1/4 inch deep.
To keep your bolts from bending, you can use thicker bolts and file down the ends to fit the holes in the retainers.
mystic_1
