Author Topic: TIG welding unit  (Read 1783 times)
SLGRS
TIG welding unit
« on: July 31, 2009, 06:07:24 PM »
Hey guys im looking for a TIG welder.  Anyone know of a good unit?  im looking to for somthing with at least 130 amps   -Thanks
Offline krazyk
Re: TIG welding unit
« Reply #1 on: July 31, 2009, 07:47:32 PM »
Being that I make my living as a fabricator I will kick in my 2 cents.
First will you need AC/DC/ or just a DC unit meaning are you just planing on steel or you going to feature into Alum also  a nice DC unit is cheaper than a AC/DC unit. I have 3 different Tig units
1. I have a little HTP 130 amp DC unit..... very portable  only use for steel  can take it any where will do any thing you need to do with a motorcycle.
2. I have a Lincoln 175 square wave AC/DC  not as portable but is on wheels, use it the most.
3.Setting in the corner is a Lincoln Idealarc 250 it is a older machine but I use it for precision project that are built on the work bench.
I don't know how much experience you have with a tig welding, but a lot of comm. collages have welding programs. You can usually take just a tig class.
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #3 on: August 01, 2009, 06:01:03 AM »
Just a heads up for all you guys welding out there.....THIS IS A MUST READ!!
http://www.brewracingframes.com/id75.htm
Dont use brake or carb cleaners for prepping metal....the excessive heat turns the cleaner into nerve gas!! :o
Main reason I only use a stainless steel brush for prepping my metal.
SLGRS
« Reply #4 on: August 01, 2009, 09:31:07 AM »
i like this idea the best..
    "2. I have a Lincoln 175 square wave AC/DC  not as portable but is on wheels, use it the most."  this will weld aluminum too right?
Thanks for all the advice guys i appreciate it!  -SLGRS
Offline krazyk
« Reply #5 on: August 01, 2009, 06:53:42 PM »
Love the squarewave best investment I made.
