Author Topic: 1975 CB550 F.....I'm not even sure what to call this thing any more!!  (Read 23801 times)
Offline verboten1
  • Der König
Re: 1975 CB550 F.....cafe?
« Reply #25 on: September 13, 2009, 06:35:33 PM »
There's no clearance to use the bars as they are, I think ill be using drag bars, the bars as they are are too low for me.
1975 CB550F
1982 XV920
2000 KLR65085
Offline 750goes
  • it will live
« Reply #26 on: September 13, 2009, 06:39:59 PM »
Nice looking project - and the powdercoating is looking good as well.
why the Ninja swingarm ? is it longer than stock??
Offline verboten1
  • Der König
« Reply #27 on: September 13, 2009, 06:48:14 PM »
Thanks!!I wanted to use an aluminum swingarm and the ninja arm fits great,
Is an inch or 2 longer, and is set up for a disc if I end up using ninja wheels.
1975 CB550F
1982 XV920
2000 KLR65085
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #28 on: September 13, 2009, 07:10:26 PM »
hmmm what year ninja swing arm? am looking to do some changes to mine this winter.  and also what seat you running. been looking for a cafe seat.  trying to get my 550 this winter ready for the wife to ride next summer.
Keep it shinny side up.
Offline verboten1
  • Der König
« Reply #29 on: September 13, 2009, 07:25:23 PM »
it's an '86 600 I believe
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #30 on: September 17, 2009, 05:17:02 PM »
Had to cut up the seat pan a little to make it fit flush, and sit on the frame better.
I will fiberglass the lip back on.
got the headlight mounts in finally, now I can rewire the bike.
not much else to show, just my little bit of progress, it has slowed down a bit due to school
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #31 on: September 27, 2009, 02:32:01 PM »
Just a little bit of progress, I picked up a tank at the swap meet last weekend, worked on it a bit over the week.
it still looks like crap, for whatever reason, it just will not look nice on the tank like it did on the side cover and the headlight.
and since I had to move them around, I figured I would take some pics of the fleet.
1975 CB550F
1982 XV920
2000 KLR65085
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« Reply #32 on: October 02, 2009, 07:39:17 AM »
bikes looking good....  I'm stalled on my 550 right now... ( moving into a new house )... but all the 500/550 threads are making me want to just throw everything in the house and get the garage ready to continue the rebuild..
Different question.... On your KLR.... what paint color do you have on it?  That looks like the IMS tank.. mines black... but it's not painted....  (sorry...not trying to derail the thread)
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Offline verboten1
  • Der König
« Reply #33 on: October 02, 2009, 07:53:56 AM »
THANKS!!!
The KLR is the stock tank, I have it painted flat balck right now, with a storm grey section in the knee indent.
the side covers are also storm grey
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #34 on: March 04, 2010, 09:10:52 PM »
exhaust is here, and I have started rewiring this bad boy.
working on procuring a ninja front end, brakes, rear end, and brakes, and maybe this will be ready to roll when it's nice, warm and sunny out!
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #35 on: March 05, 2010, 10:14:18 AM »
got the exhaust mounted, I may still try to fix up the stock header, it looks way nicer. and then i will add a more modern sport bike mufler, at an angle
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #36 on: March 15, 2010, 08:51:12 AM »
welp.....I thought I was on the homestretch, but it appears i will be doing more mods before riding this thing!
going to pick this up in a couple of hours.....
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
Re: 1975 CB550 F.....exhaust.....forks.....3/15
« Reply #37 on: March 16, 2010, 02:05:33 PM »
I test fit the front end today....man it's a pain when the exhaust goes under the frame!
it's a 2000 SV 650 Front end with brakes and everything. dual pot tokicos!
1975 CB550F
1982 XV920
2000 KLR65085
Offline fastbroshi
  • Puppet
« Reply #38 on: March 16, 2010, 03:27:28 PM »
  Is that top triple upside down?  Is that just mocked up or do you have the bearings installed?  Would like to know the measurements on the stem, like length from base at the lower triple to the top, lower and upper diameters.
Just call me Timmaaaaay!!!
Offline verboten1
  • Der König
« Reply #39 on: March 16, 2010, 03:46:49 PM »
it appears to be right side up, as I can see where the risers sit.
it is just mocked up, I plan on using the stem from the original triples, as that will make the transition the easiest.
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #40 on: March 18, 2010, 02:14:31 PM »
if i can find my calipers, i will try to get some measurements for you.
well, I found that the stock honda stem fits in the Suzuki tree PERFECTLY!!!
step 1: grind weld, press out Honda stem
step 2: heat up and press stem out of tree, breaking retaining clip that I ddnt know was there....lol
Step 3: tap stem into tree, weld....VOILA!
step 4 will be to powedercoat the triples black, like the old one
1975 CB550F
1982 XV920
2000 KLR65085
Offline fastbroshi
  • Puppet
Re: 1975 CB550 F.....Fork swap in progress~!! 3/18
« Reply #41 on: March 19, 2010, 03:35:35 AM »
Any luck finding the calipers?  Would really like to know the dimensions of that stem.  Regardless, knowing that SV lower fits is wonderful, that really opens up some doors considering how popular the SV/GSXR front ends are.  Also, what year is that front end?
« Reply #42 on: March 19, 2010, 04:27:14 AM »
I did the same thing with my 1989 GSXR1100k front end swap, the Honda stem pressed straight into the Suzuki lower clamp.....
traveler
« Reply #43 on: March 19, 2010, 04:52:31 AM »
looks good.....I assume you will use a matching rear mag wheel??
~Joe
Offline verboten1
  • Der König
« Reply #44 on: March 19, 2010, 07:54:17 AM »
no sir, I am going to check @ my parents house when I go use the welder today. I did not forget your request!
It's a 2000 SV 650
that's also cool to know!
~Joe
Thanks! Eventually i will have a matching rear wheel. The ninja swingarm has a 17 mm axle, as do both 1st gen SV, and some GS500 Wheels, which both match the front. My issue there is they use a 525 chain, and I want to keep it to OEM parts, so that I do not have to custom order wear parts
1975 CB550F
1982 XV920
2000 KLR65085
traveler
« Reply #45 on: March 20, 2010, 09:24:36 PM »
www.sprocketspecialists.com
Check with them....should be able to get you a sprocket that will work with a 530 chain.  It'll be a custom sprocket, so if you would like to chage your gearing, you can do so at the same time.  More teeth on rear sprocket means quicker acceleration around town, but higher RPM on highway.  Opposite is true with less teeth.
~Joe
Offline verboten1
  • Der König
« Reply #46 on: March 20, 2010, 10:57:53 PM »
Cool, i am going to see if what the measurements are on the SV rear wheel, see if it even fits in my swingarm, because the guy still had it.
I just hope it's not too wide to make the chain not line up
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #47 on: March 21, 2010, 12:02:02 PM »
I just talked to the guy i got my front end from.
The SV wheel from sprocket to rotor is only 7/8" wider than the Stock Honda wheel from sprocket to outer part of brake drum.
This SHOULD work out pretty well, I may need to mount a smaller tire, as the SV uses a 160 rear, and I bet the chain may hit that.
he is going to hook me up with the wheel, a tire (and all the spare rear SV tires I could ever need lol), the rotor, sprocket, all the spacers, and a bunch of other stuff if he can find it.
1975 CB550F
1982 XV920
2000 KLR65085
« Reply #48 on: March 21, 2010, 04:05:22 PM »
CycleX have 10 mm offset front and rear sprockets, i will be using a 10mm offset front to get things mated up properly.
Her's a pic
http://www.cyclexchange.net/index%20pics/offset%203.JPG
Offline verboten1
  • Der König
« Reply #49 on: March 21, 2010, 04:24:45 PM »
yeah, that price, is why it has to work! LOL
1975 CB550F
1982 XV920
2000 KLR65085
