Author Topic: Great deal on Dyna S ignitions...  (Read 5221 times)
« on: November 25, 2005, 03:07:49 PM »
http://dynoman.net/sale.html   He is a good guy to deal with.
Offline Phaedrus
Re: Great deal on Dyna S ignitions...
« Reply #1 on: November 25, 2005, 03:11:25 PM »
Not affiliated with these guys or anything, but I got my Dyna S from these guys and they were quick to ship.  And they have them for $120.  Gonna get some coils and wires from them next.
http://www.z1enterprises.com/
Jason
1976 CB550 - Texas
« Reply #2 on: November 25, 2005, 03:11:42 PM »
Have PMed you young Sir.
« Reply #3 on: November 25, 2005, 03:15:40 PM »
Received and replied to sir.
« Reply #4 on: November 25, 2005, 03:23:34 PM »
Gotcha.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: November 26, 2005, 09:41:30 AM »
does anyone have a qualified comparison between the two? are they pretty much the same thing?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #6 on: November 26, 2005, 10:38:28 PM »
sorry.. i just realized they are both dyna s ignitions. i looked at the second one wrong and thought it was a different product.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #7 on: November 27, 2005, 11:16:49 AM »
OK, we forgive you.   ;D
apormarkos
« Reply #8 on: November 27, 2005, 06:28:37 PM »
i ordered from these guys as soon as i heard it was $120.  got it in just a couple of days.  still yet to install it though.
/a
Offline mrbreeze
  • Not your average
« Reply #9 on: November 27, 2005, 09:49:57 PM »
OK...I just have to ask.... What exactly are you guys getting for $125-150? you are showing pictures of the pick-up/breaker plates but what about the module unit? I bought mine out of Dennis Kirk about 4 yrs. ago for like $375.That plus Accell coil 7 wire set for $150. If you guys are paying only around $120....are you getting the module with it?
MEMBER # 257
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: November 27, 2005, 09:54:53 PM »
The Dyna-S doesn't have an electronic module, it only replaces the points, condensers, and rotor, not the stock mechanical advance.
Offline mrbreeze
  • Not your average
« Reply #11 on: November 27, 2005, 10:31:58 PM »
Well mine has a module.Blue box with built in retard-advance,timing light etc.I wasn't aware of a setup that runs without it.
MEMBER # 257
« Reply #12 on: November 28, 2005, 04:59:26 AM »
You've got the Dyna 2000. It is a digital ignition and is a much nicer unit than the Dyna S. It also allows you to choose from 5 different advance curves.
Offline mrbreeze
  • Not your average
« Reply #13 on: November 28, 2005, 06:37:56 PM »
Yeah,thats what I have.I didn't realize they had a system without the module.I probably would have bought the cheaper one had I known.
MEMBER # 257
whoismattclark
« Reply #14 on: December 14, 2005, 10:21:53 AM »
Quick question to all you Dyna users.  I acquired a second CB550, this one having a Dyna S installed from the PO.  From the looks of it, he kept the stock coils though.  Anyhow, I'm a newbie when it comes to EI, never had the pleasure.
So, what kind of maintenance do these guys need?  Points, no more!  That I get, but do I still need to check the timing at regular intervals?
thanks,
Matthew
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #15 on: December 14, 2005, 11:47:42 AM »
Nope.
Fit it and forget it.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Gordon
  • 750K1, 550K2
« Reply #16 on: December 14, 2005, 11:54:37 AM »
If you get really bored, you can.  It's not a bad idea to occasionally (maybe once a year) check with a strobe light to make sure the stock advance mechanism is working properly, but the Dyna-S is basically a set once and forget kind of thing.  The stock coils will work fine with that ignition, but you won't get the full benefit unless you upgrade to newer 5ohm coils, or (if your charging system can handle it) 3ohm.
« Reply #17 on: December 14, 2005, 09:22:41 PM »
So, what kind of maintenance do these guys need? That I get, but do I still need to check the timing at regular intervals?
thanks,
Matthew
Welcome Matt, and the short answer is...........(drum roll)............... No! Cheers, Terry. ;D
« Reply #18 on: December 14, 2005, 09:29:59 PM »
Hmmnnn, an interesting quandry. I need a Dyna 2000 for my racer engine, and you wish you had saved some dough by just buying the Dyna S? Now I have an (almost) new Dyna S in a box at home, so maybe we could do a deal? Do you need an oil cooler for your bike, by chance? (maybe not until summer, I guess) Cheers, Terry. ;D
Offline CB750R
  • 77 CB750F
« Reply #19 on: December 14, 2005, 11:38:32 PM »
I'm starting to work on my big motor project 900+cc kit, will the stock Dyna S suffice or will I need the 2000???
This motor is going to be cammed, with new valvesprings, Earls oil cooler, attached to what I believe is a Terry's adapter.
gaijin
« Reply #20 on: December 15, 2005, 01:08:51 AM »
Hum, I've been wondering about Dyna S lately so I'll as here: My mechanic boss told me to steer away from DynaS ignitions because many failed regularly after about 3 years. Has anyone had this happen to them? My boss also mentioned that those were older model ignitions and perhaps they've improved by now, but I thought I'd ask.
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: December 15, 2005, 04:13:59 AM »
I've used the exact same Dyna-s module on four different bikes over the last six years and haven't had a problem yet.
If you decide to get one, make sure you get the DS1-1, not the DS1-2.  The 350 and 400 use a smaller magnetic rotor.
« Last Edit: December 15, 2005, 04:16:41 AM by gordon »
« Reply #22 on: December 15, 2005, 04:18:01 AM »
It's an old wives tale mate, put about by old timers who like to listen to the "clack clack clack" of contact breakers. Another one for "Myth-Busters", methinks! Cheers, Terry. ;D
« Reply #23 on: December 15, 2005, 04:24:04 AM »
I would use the 2000 as you can choose between 5 digital advance curves. I have it on my 915.
Offline dusterdude
« Reply #24 on: December 15, 2005, 05:46:17 AM »
why not the dyna 4000?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
