Author Topic: Wheels????  (Read 1504 times)
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
Wheels????
« on: September 04, 2009, 01:08:03 PM »
Ok been throwing around the idea and as much as I love the rear drum brake setup I want to convert to rear disc.  Been having my eye on some mag style wheels off a 750 with rear disc and was wondering what wheels in that style will fit or could be made to fit?  Anyone done this conversion before?  I just want to get my current running 550 together and handle good enough so when the wife gets her change to ride it to work and school  I won't be nervous or worried it won't start or handle good enough for her.  Plus I want some more stopping power since I'm riding with guys on newer gsxrs and kawi's.
Keep it shinny side up.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: Wheels????
« Reply #1 on: September 07, 2009, 05:20:29 PM »
did you check with fishhead?
he does some awesome stuff.
http://www.fishheadbigbrakes.com/index.html
« Last Edit: September 07, 2009, 05:44:19 PM by Industrial Cafe »
Offline Beans
  • 1975 cb550f
    • bean's place.
Re: Wheels????
« Reply #2 on: September 07, 2009, 07:32:50 PM »
Thanks for the link. I was thinking about some mag wheels and doing the conversion to disc brake.   looking on ebay as we speak to try and find some wheels. my cousin has a xs650 he is building so im going to get his rear and front wheel and see if I can mock something up to make it work since he is going to get a set of spoked wheels laced up for his build.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: Wheels????
« Reply #3 on: September 08, 2009, 07:08:40 AM »
The stock XS 650 rear wheel is a 16 incher and the sprocket bolt pattern is rather large (6 bolt-the sprocket is kinda like a sprocket ring).
   The RD's and XS 400/500 (and others) use an 18 inch wheel and the sprocket bolt pattern is on the same bolt circle ( but 4 bolt) and would probably be a better wheel to start with. Using the RD/XS 500 rear wheel with require the bearings to be changed to 20mm. Personally I would use the XS 500 wheel as it has the spokes machined for more caliper clearance (the spokes on the RD wheel are "flat", where the spokes on the XS 500 wheel are dished).
 1) RD wheel (spokes are "flat"). It shows the size of the sprocket/ sprocket bolt pattern also.
 2) XS 400/500 Rear wheel. The spokes have extra machining to give them the dished look (the stock XS 650 wheels are like this also). This extra maching gives more clearance for different calipers.
« Last Edit: September 08, 2009, 07:11:04 AM by fishhead »
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Beans
  • 1975 cb550f
    • bean's place.
Re: Wheels????
« Reply #4 on: September 08, 2009, 10:01:52 AM »
Ill have to check it more out wqhen I get home but it give me some things to look into.  I never thought to look at rd wheels or the xs 400/500 wheels.   Ill have to look more later on tonight and see what I can find.  Been trying to find a set of comstar wheels but am having no luck.
Offline bert96
  • past ride
Re: Wheels????
« Reply #5 on: September 08, 2009, 05:43:31 PM »
 I'm doing the same thing on my k4. I bought a rear mag wheel from a rd400 '76 with the rear caliper from a xs750 '78.If you want to keep a 48 teeth in the back you'll need to buy a sprocket from them(that's what i did)
http://www.rebelgears.com/officialrebelgearshome.html
For the front i have bought a xs750 '78,i'll install my VTR rotors after some work on it to make it fit.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Beans
  • 1975 cb550f
    • bean's place.
Re: Wheels????
« Reply #6 on: September 08, 2009, 10:16:37 PM »
Bert
thanks for the info that helped me out alot.  now I know what I need to get for wheels.
