Author Topic: WTF! Completely stuck oil filter bolt, '74 CB550  (Read 7502 times)
Offline zoo mob
« on: September 06, 2009, 10:40:18 PM »
Well, not real happy right now, the CB550 is giving me fits, the oil filter bolt simply refuses to come off. First, it begins to strip with a socket, next, vise grips to no avail, next slotted it with a dremel and couldn't get it to go with a flathead, last, worked into it real good with my impact driver, the result was a twisted tip to the impact driver, I'm lost, Help.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline TIM TINGEY, age 55
  • Service manager Matts Vintage Motorcycles
  • 916 208 0935
Re: WTF! Completely stuck oil filter bolt, '74 CB550
« Reply #1 on: September 07, 2009, 12:20:47 AM »
At this point it'll probably be easier to weld a nut with a 17mm hex to whats left. A good mig or tig welder should be willing to do this. Make shore all ground wires are disconnected, un hook the battery.  ;D ;D ;D. The stock bolt had a 12mm head, i'd recommend one of the aftermarket bolts with a 17mm head. For most owners it'll allow easier removal. Just make sure not to overtighten the bolt just because you'll be using a bigger wrench. One last idea: using a chisel with a 1/2 inch head (a good sharp tip ) strike the head where the flat lip rests against the filter, in the direction to lossen it (counter clockwise). . . to help, take the hammer and strike the head straight on to jar the threads. Do this 2 or 3 times then try to loosen bolt again.
Offline KeithB
« Reply #2 on: September 07, 2009, 04:14:26 AM »
Have you tried warming up the engine first?
I have found this to work with a "stuck" spark plug once.
Nanahan Man
Offline Calflash
« Reply #3 on: September 07, 2009, 05:07:44 AM »
Put your vise grips on  the bolt head.  Hit the head of the bolt with a hammer as you turn the vise grips.
Calflash
US Army
Nam 66-67
80 CB650
Offline Johnie
« Reply #4 on: September 07, 2009, 05:42:17 AM »
I have seen good results from a basic pipe wrench.  It bites good.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline CrashBar
« Reply #5 on: September 07, 2009, 06:06:52 AM »
....to trade in these wings on some wheels...
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
« Reply #6 on: September 07, 2009, 06:20:32 AM »
I got a mangled bolt out Andy by taking a socket that was smaller,probabably an 11mm and pounding it on to the mangled head of the bolt with a hammer. It bit down real nice and came out. Put a little heat and PB in the equation also.
Offline mark
« Reply #7 on: September 07, 2009, 07:05:21 AM »
Somebody here took a sawzall to the housing and through the bolt......
Kinda messy but got past the chewed up stuck bolt in a hurry.
F you mark...... F you.
Offline spitfire
« Reply #8 on: September 07, 2009, 07:10:54 AM »
Normally the hammered on 11 mm socket works, but it's probably more to do with warming up the engine and hitting the end of the bolt with a hammer to jolt the threads that does it.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline crazypj
  • I'm brill, me
« Reply #9 on: September 07, 2009, 07:28:20 AM »
Your wasting your time with a normal chrome plated 12 point socket.
Get a cheap set of impact sockets, 6 point is the ONLY way to go (cheap set is less than a single Snap-On 12mm)
 You don't mind beating , grinding or welding on them either.
I've found the steel is as good or bad as anyone else's
I'm still using the set I bought in 1971, 14mm is a bit worn, but not as bad as the Snap-On I replaced it with in 1995 (used to use 14mm a lot doing engine work, almost all engine bolts have 14mm nut)
PJ
duzatun
« Reply #10 on: September 07, 2009, 08:51:12 AM »
zoo i had the exact same prob on my 550 cpl months ago unhooked wires got the welder out tacked a 10 mm rod on the nut or what was left of it and just the heat transfer done it could of undun it with my fingers after that
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« Reply #11 on: September 15, 2009, 05:25:15 PM »
Could you use a propane torch to heat up the bolt? I found that mine is stuck too. I can't warm up the engine because most of it is in pieces ;D
Offline Flying J
« Reply #12 on: September 15, 2009, 05:31:34 PM »
I used a sawzall on my 750f. I didnt need the filter cover or the bolt. I needed the motor out of the frame. Anyway what i found was that when this is the problem its not the threads that are locked up its actualy the head of the bolt that is stuck to the filter cover. After i cut the head off with the sawzall and pulled the filter cover off the bolt came out by hand. I also have welded a phillips bolt to it and that worked good.
