Author Topic: CB160 Bottom End Rebuild  (Read 2620 times)
Offline OakBehringer
« on: October 06, 2009, 11:02:59 AM »
Pulled the head off the barn bike I just got to find cylinder #1 blown to pieces- pieces which are surely now in the crankcase. So, I'm going to do my first bottom end rebuild. Are there any special tools that I will need beyond that which is needed for a top-end rebuild? I have a vast array of wrenches and sockets, torque wrenches, impact driver, digital calipers...
Also, what can I expect to (roughly) spend on the bottom end rebuild, provided there are no major and unexpected problems?
Thanks!
Adam
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Re: CB160 Bottom End Rebuild
« Reply #1 on: October 06, 2009, 12:50:54 PM »
Adam, I've never worked on a 160 but most of the small twins are much of a muchness.
The tools you have will do fine with the addition of a set of circlip pliers.
The rotor will probably pull off useing the back wheel spindle.
Remove the rotor bolt and screw in the wheel spindle. When it is up against the end of the crank, put a bar through the hole in the end of the spindle and give it a sharp hit, it should fly off.
Sam. ;)
« Reply #2 on: October 06, 2009, 11:18:44 PM »
Sweet, thanks. This will be my first bottom end rebuild, and I wasn't quite sure.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
« Reply #3 on: October 07, 2009, 12:33:02 PM »
Have you got a work shop manual?
Sam. ;)
« Reply #4 on: October 07, 2009, 12:57:15 PM »
I have the PDF of the Honda shop manual. Computer is viewable from the shop, so that should be enough.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
« Reply #5 on: October 08, 2009, 11:46:55 AM »
Adam, it looks a simple job from looking in the manual and using the rear wheel axle as a rotor puller was mentioned in there as well.
Sam. ;)
« Reply #6 on: October 08, 2009, 12:12:44 PM »
Sam. ;)
That's nifty. Are you looking at the Haynes? Or the Honda shop manual?
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
« Reply #7 on: October 08, 2009, 12:26:45 PM »
Haynes :( :( :( :( :(
