Author Topic: Reviving Shenanigans CB550 Cafe: Phase longest build possible?  (Read 53558 times)
Offline Little_Horse
    • My cafe build
Re: Reviving Shenanigans CB550 Cafe: Photos 2\15
« Reply #125 on: March 12, 2010, 10:54:34 AM »
I have been struggling with leaks too, seems it is the way my friend. Some people may get lucky in that regard but how many people are later posting on their original build thread their leak failures. I know I mentioned it but did I mention because of it I now need to repaint the motor. So don't think its just you.
You might be able to find a cheap gasket kit like I did on ebay. The motor is dirt simple to work on. It has an over exccesive amount of bolts and nuts but it is not complicated. You can download the manual section "engine" and it walks you through tear down and re assembly.
How did you verify that 1 and 4 where not firing?
Hang in there and godspeed!
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #126 on: March 12, 2010, 12:45:53 PM »
hang in there man, i've been working on a project non stop and am getting sooooo burned out that all the little things the last couple days have been wearing me down. with you working at a dealership you'll probably be less enthusiastic to sort out BS with your own bike.
worst case scenerio, TAS Classic Motorsports sells the Vesrah complete gasket kit for our bikes for about 65$. That, and you know the ignition issue is going to be some little nit picky crap, you'll just have to sort it out when you have the patience.
as for the right tools, when I did my full rebuild i used my basic tools, and the few things I needed special I bought at harbor freight, took good care of, then returned them when I was done.
1974 CB550
Forever West
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #127 on: March 12, 2010, 01:12:03 PM »
Great build bud. Keep your head up!
Do you have a close up of those fork boots? How are they attached at the top?
I bought some fork ears off here and they are the wrong style. They dont have the attachment at the top for the fork boots. So I was curious how you did it.
Thanks!
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline 000jeremy
« Reply #128 on: March 12, 2010, 01:39:10 PM »
It sounds like you've got your ignition problem sorted out and I cant really offer any technical advice that you haven't already thought of, but the right music always powers me through such a funk.  Godless Noise by Infernal Stronghold with a little Townes Van Zandt got me through a few tough days, but we all have our own tastes.
Offline Shenanigans
  • Right turn?
« Reply #129 on: March 12, 2010, 03:34:11 PM »
I guess anger is good motivator because I worked on the bike all day.
I verified 1-4 not firing by riding and then pulling the number one plug cap off, no difference and the motor ran the same. Did the same with number 4. Same thing.
I put a multimeter on EVERYTHING. Evey thing was in check. Searched the wiring harness top to bottom, took off all electric tape. I finally found a tiny wear spot in one of the wires that go from the ignition to the coil. It also happend to be right next to a tiny spot on the frame that had been rubbed raw from the gas tank. It must have been somehow jumping from that tiny exposed spot past the insulation to the frame causing the coil not to fire. I wrapped it up in a ton of electrical tape and the its now firing. So far anyways.
Float was sticking, mallet solved it.
Found a good cam end cap cover and stuck it on. One leak down. Cleaned the motor and put a new oil pan gasket in. No leaks, rode it around and it was leaking. Took off the sprocket cover kind of hoping I just messed up putting it on. Shifter seal seems good. I threw some baby powder at on that area. Leak is coming from the god damn oil pump!
I still have to figure out how to seal the aftermarket tappet covers but worse case I can just dig the seal out of my old caps.
Fork boots are from cycle-x and attach directly from the fork slider to the fork tube.
So any advice of what is mostly likely leaking with the oil pump?
Offline Shenanigans
  • Right turn?
« Reply #130 on: March 12, 2010, 03:52:12 PM »
The problem area.
Offline Frankenkit
  • Industrial Strength
« Reply #131 on: March 12, 2010, 03:59:13 PM »
....I'm curious too. That looks like my leak.  (but mine's pretty slow, and I'd rather not touch it until I have to...)
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline IAmCitizenMe
« Reply #132 on: March 12, 2010, 04:10:02 PM »
I had a leak in the same spot. I got some o-rings from Bike Bandit which slowed the leak to an occasional drip.
Offline Shenanigans
  • Right turn?
« Reply #133 on: March 12, 2010, 04:21:53 PM »
How hard of a job was it? After finding some pictures of the oil pumps on Ebay it seems pretty simple. Just the one o-ring. I tried to take of the oil pump on my extra 550 bottom end but broke my impact driver bit.  ::)
« Reply #134 on: March 12, 2010, 04:31:43 PM »
I didn't have a problem with it. There are two small o-rings and a larger one.
You broke you impact driver bit? Impressive.
Offline fastbroshi
  • Puppet
« Reply #135 on: March 12, 2010, 07:14:28 PM »
  I think I read on here the correct O rings are MIA from Honda, just need to get the correct size.
Are these it (#18)?  If so I'd google it, maybe their available in viton from somewhere:
PN: 91301-268-020  13.6X2.4
« Last Edit: March 12, 2010, 07:20:27 PM by fastbroshi »
Just call me Timmaaaaay!!!
Offline Frankenkit
« Reply #136 on: March 12, 2010, 07:42:29 PM »
18 or 19?
1973 CL350- Lola?
Stuff for sale
Offline fastbroshi
  • Puppet
« Reply #137 on: March 12, 2010, 09:44:54 PM »
I'm betting it's the smaller ones.
traveler
« Reply #138 on: March 13, 2010, 08:29:43 AM »
Seriously....if you guys find a source for these babies, PLEASE, PLEASE let me know....I got a leak too!.... >:(
~Joe
Offline smack
« Reply #139 on: March 13, 2010, 09:46:56 AM »
Hey everybody...I have that exact same leak. I just ordered all three O rings yesterday from my local honda
dealer Part# 91301-268-020 for the 2 small ones (14mm) and Part# 91302-250-010 for the big one (47mm)
I hope that this fixes the leak. But I did notice that when I took my Oil pump off, I only have 1 of the
small O ring retaining collars (#6 on the diagram) I can't seem to find those anywhere. I'll let you know if
the new O rings solve the leak.
« Reply #140 on: March 13, 2010, 11:31:49 AM »
I actually checked my oil leak today and, as it turns out, it DID fix the leak. The oil is dripping from the rocker arm covers. I replaced those with new o-rings from Bike Bandit and it still leaks. But the oil pump is tight as a drum.
Offline Shenanigans
  • Right turn?
« Reply #141 on: March 13, 2010, 07:08:40 PM »
As soon as I can track down that O-ring I will do it. Its only like a couple bucks but I dont want to wait a week for it to ship. My next day off is Tuesday so I hope I can get it done then if not sooner!
Offline Shenanigans
  • Right turn?
« Reply #142 on: March 15, 2010, 07:26:43 PM »
God damn it I hate seized bolts. Did they not use anti-seize in the 70's?
All three bolts had to be drilled out. Is there any reason I cant replace them with a normal bolt? Also the offending o-ring. I went to harbor freight and got one of the metric o-ring packs. One of them was pretty close so I tried it. I reused the big o-ring. I am going to ride it to work tomorrow to see if it worked, if not I am going to order from Honda tomorrow.
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #143 on: June 16, 2011, 02:57:29 PM »
Whatever happened to the refresh???
I happened upon this accidentally, looking for info for steering dampers on a 550.
Ever get this ready for the next trip?
Hope so.....
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Shenanigans
  • Right turn?
« Reply #144 on: June 25, 2011, 06:59:35 PM »
Been too busy riding and beating it up. Its starting to get close to the next tear down. That oil leak was the last loose end. I never really got the leak to go away until recently. Long story short it DID turn out to be the inspection cover o-ring.
Life is trying to get in the way of another trip but its not lost yet.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #145 on: June 25, 2011, 08:42:46 PM »
I'm sure if you keep it in the back of your mind, eventually life will lead you down that road once again.
Until then, keep beating it up!
~Sophocles
Online scottly
« Reply #146 on: June 25, 2011, 09:11:16 PM »
Hey Chris!! Good to hear from you! If you're busy riding and beating up the 550, I guess the arm has healed well. Too bad you missed the relay; your photo-journalistic skills would have come in handy.
Offline Shenanigans
  • Right turn?
Re: Reviving Shenanigans CB550 Cafe: Phase 3?
« Reply #147 on: September 12, 2011, 12:48:42 PM »
Well, something in the motor finally gave. It sounded pretty bad, "Click click clunk clunk  BAHHH" (or something similar) and then she seized. I expected it to be pretty bad and I finally got a chance to open the motor up. I was thinking it ate a valve or something along those lines. Turns out the far side oil passage under the cam appears to have lost pressure/got clogged and friction had a little bit of a party. When I took the head off I did not see anything in the passage and oil jets but who knows. I have another head that I am going to rebuild but I wanted to ask if this head is completely toast because of the wear?
It has also got me thinking. The Click click CLICK CLUNK sounded pretty horrible. I could feel it in the motor. It felt in the bars like someone was hitting the internals with a big hammer or something. So I need to check over the bottom end somehow. The cam scoring may have been an old wound.
Since I now have to rebuild the motor, I might as well put some good stuff in there. So phase 3 it is.
Here is the plan: I have a set of CB750 pistons Soos was kind enough to mill down for me. So those are going to go in. Going to do a decent cam and springs along with fresh gaskets, cam chain and O-rings. Rebuild the head. I also really want to do external oil lines to the head just to save the hassle of those leaking passage o-rings down the road. Maybe a little more cosmetic stuff too. I have an aluminum rear rim, just need to find a front. Maybe clean polish and paint some more stuff to get it looking better. I cant give up the 4-4 pipes so I might find some good stock headers and see what kind of mufflers I could rig up.
Offline lucky
« Reply #148 on: September 12, 2011, 08:08:48 PM »
It is lucky you were not killed on that trip.
The confederate flag  probably did not help. You will learn about that someday I hope.
All those hormones runn'n around.
« Last Edit: September 14, 2011, 07:22:54 AM by lucky »
Offline Elniniomuchachos
« Reply #149 on: September 13, 2011, 08:53:22 AM »
You should add a oil pressure gauge to your setup. I picked one up and am going to install it this weekend. Hopefully it will help me prevent blowing it up.
I see you are in Tempe. Any interest in getting a little shop or weekly ride together or something?
