Author Topic: Mikuni carbs for a 460/4?  (Read 11974 times)
Offline Tel#277
« on: November 05, 2009, 02:22:25 PM »
Hi all,
Just wondered if anyone has tried fitting 4 seperate 26mm Mikuni carbs (as fitted to pitbikes) to a 400/4?
I'm prepping my Tony Foale chassis'd version for CRMC in the UK next year - and my attempts to find some used 26mm CR's have proved unsuccessful.....
The bike has a 460 Yoshimura kit & cam, gas flowed head etc, and the original carbs look tiny.
Anyone got any ideas?
Thanks in advance...
Re: Mikuni carbs for a 460/4?
« Reply #1 on: November 05, 2009, 02:55:30 PM »
Why don't you run Keihin CR26's?
  • Moderator
« Reply #2 on: November 05, 2009, 03:04:59 PM »
The modern ones are not allowed in CRMC racing Mike.
Welcome to the forum Tel#277, how about a name and where you are in the UK, we also like pictures ;D ;D ;D
There are quite a few people on here that might come to your rescue.
Sam. ;)
Offline simon#42
  • liverpool
« Reply #3 on: November 05, 2009, 03:19:04 PM »
depends what class its entered in sam , they would be fine in the post classic class , not sure where else a 400 based racer would be eligible at the classic club .
  • Moderator
« Reply #4 on: November 05, 2009, 03:22:52 PM »
That's why I am a drag racer and only a spectator at real racing Simon.  ;D
Sam. ;)
  • Moderator
« Reply #5 on: November 05, 2009, 03:33:01 PM »
If what Simon says is correct and it probably is, you need to read this thread Tel#277.
http://forums.sohc4.net/index.php?topic=42903.0
Sam. ;)
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #6 on: November 05, 2009, 06:22:23 PM »
i have the solution to your query but refuse to divulge in the absence of pictures of tony foale bikes.
i lied. i have nothing.  :-[
but take pity on me... i require visual moto stimuli.   :'(
1974 CB550K
                                  Your 1%er name
Offline Tel#277
« Reply #7 on: November 05, 2009, 06:26:10 PM »
Its already had the nod to race in the 500 aircooled class group 2 period 3, gona try & show them Suzuki T500 stinkwheel things the error of their ways! ;)
I've got to put it back to its original monoshock rear end for eligibility reasons (it was previously raced with forgotten era in the early nineties who insisted it had to be twin-shocked!) ???
The later type CR's are widely used in CRMC now, but 26's seem ultra rare, I'm a cnc machinist, and I could easily machine out some stock carbs to something like 24-25mm, but I quite liked the idea of the individual 26mm Mikuni smoothbores for some strange reason (maybe I just like a challenge), I could easily make my own flange adaptors to suit the stock rubbers (or can I fit larger ones from a 500/550?)
Its a bit of a departure from the big Z based Kawasaki's I've built & raced in the past (and still do) but I'm looking forward to it.
I'll try to put some decent pics on soon. ;D
By the way Sam - I'm based in N.E. England (Durham)
  • Moderator
« Reply #8 on: November 05, 2009, 07:35:08 PM »
OK, we'll call you Terry or Tel for short. I think we have 276 Terrys on the board so you can be #277. ;D ;D ;D ;D
Tel, did you not see this thread. http://forums.sohc4.net/index.php?topic=42903.0
Sam, near Manchester untill Wednesday. ;)
Offline Tel#277
« Reply #9 on: November 05, 2009, 09:00:03 PM »
Yes I read the thread - but I simply cant find a used set of CR26's - not yet anyway, in the past (probably my Z background here) I've always preferred Mikuni's, and I figured with new VM26 smoothbore carbs being available at £20 each it may be worth a shot? - just wondered if anyone else had tried a similar mod?
Offline rudi
« Reply #10 on: November 05, 2009, 09:28:57 PM »
Hello from Germany,
yes positiv I put Mikunis on my CB 400 F Projekt . Look at the Picture.
Details on request.
My next Offer : Use Kawasaki ZXR 400 Carbs !!!!!!!
Same dimension as CB 400 f Orig. and with a Alloy Adapter and Intake Rubbers ready to use !
Dont forget to construct a Air Box or use K.u. N Individual Filter othewise the CV Carbs wont work....
Offline Tel#277
« Reply #11 on: November 05, 2009, 11:53:42 PM »
Thanks for that Rudi,they look like the old VM29's - do you know if they are 26mm? or what they came from?
Offline turboguzzi
« Reply #12 on: November 06, 2009, 02:47:04 AM »
Have used VM26's rack on my CB500 racer with really good results, they came off a GS750 I believe
BTW, 26VM from in line fours are not smoothbore, but just because of that, have amazing response down low.
the 75-100-75 spacing was spot on for the 500, you'll have to redo the mounting plate for the spacing of your 400 I'd think
I think you'll go through some serious hassle trying to sort an easy to synchronize  linkage with single carbs and your wrist will have to deal with four return springs but have seen it done
TG
« Last Edit: November 06, 2009, 02:54:29 AM by turboguzzi »
Offline simon#42
  • liverpool
« Reply #13 on: November 06, 2009, 10:00:42 AM »
yes that looks like a good new class , i watched it at brands earlier this year . all the front runners where using rd based bikes and it would be nice to see some variety .   i have never understood the classic clubs classes , group 2 i suppose is for road derived bikes ?
oh and the forgotten era club insisted it had twin shocks because it was raced in the twin shock 500 class if i remember right . if it had been a monoshock it would have been in with the tzs and rgs  and would not have been competitive at all .
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #14 on: November 06, 2009, 10:57:45 AM »
Alot of the "other" makes and models (Kaw 900/100 in particular ) use the 750 sandcast 1 into 4 throttle cable when going to the 4 individual carbs.
 What I have done in the past was to modify "other" application carbs to fit the application that I wanted them to fit on .
 The 1st pic is of Mikuni 38mm flatslides modified to fit the Suzuki GT 750(off a 780cc snowmobile). The carb spacing was altered to fit the intake spacing on the GT and of course, rejetted.
 The 2nd pic is a set of Mikuni 33mm flats modified for the 750 SOHC. Spacing was altered, jetting was altered,etc.
 I prefer to modify the carbs with a single throttle shaft as I hate the 4 seperate throttle cables that seam to always need to be adjusted and stretch at different rates.
The easiest (allthough, not very easy) would be to get a set of Mikuni 26's off a 76 KZ 900 (the 76 has the"smoothbore" style slide adjusters) and replace the carb mounting plate with a custom made one (like Rudi's set).
3rd pic:
 The 76 KZ 900 carbs have the 2 screws that hold the idle screw mount on at a 45 degree angle (they usually have the "connector Bracket" for the carbs shown-stock). These have the Smoothbore style slide adjusters.
4th pic:
The KZ 1000 / GS 750 usually have a different mount for the Idle screw bracket/Cable bracket (some KZ 1000 have the idle speed screw from the bottom). These 2 screws that hold the cable mount to the carb mounting plate are pointed down (not on a 45 degree angle, like the 76 KZ) . These carbs have the later style adjusters and are not as "easy " to work with  (when modifying) as the earlier 1976 26mm carbs are.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline rudi
« Reply #15 on: November 07, 2009, 02:42:02 AM »
Here are a detailed Pictured from the Carbs
if you want more Details , please let me know, I prefere Telefon because my Computer Expieriance and my two Finger System makes it difficult...........
Dont miss the Chance...
Look at www.cb400f.de......
« Reply #16 on: November 07, 2009, 04:23:03 AM »
Those are a tight squeeze rudi, would you mind showing us a pic of the opposite side too?
Offline rudi
« Reply #17 on: November 07, 2009, 08:46:15 AM »
Ok i will do my very best.............
Some more pictures ........
Offline rudi
« Reply #18 on: November 07, 2009, 08:58:19 AM »
The PC kills me....................
Offline rudi
« Reply #19 on: November 07, 2009, 08:59:53 AM »
aaargh...............
Offline Tel#277
« Reply #20 on: November 07, 2009, 09:17:40 AM »
Thanks for all the help - looking at a couple of the links Rudi sent maybe I should look at Amal concentrics as an option....
If I can figure out how to post pics I'll put some on!
Offline Tel#277
« Reply #21 on: November 07, 2009, 09:26:17 AM »
Here's some of the Foale in its previous (twin shock) guise, as well as being monoshocked as per original, I will be switching to bigger discs & Brembo or Lockheed brakes, and of course a fairing (probably a Davies Motorsport K4 item)
I'm undecided about a colourscheme, my thinking is the red with silver fairing thing is a little before its time...
http://s669.photobucket.com/albums/vv59/Telsport-racing/
Offline turboguzzi
« Reply #22 on: November 08, 2009, 05:07:14 AM »
very nice tool! pretty rare too,
from my experience, you should reel in the T500's but dont expect to get too near to the RD 350's unless your cut off date is 72' (so those are only R5's with 5 speed boxes).
definetely go for bigger discs.
cool stuff rudy,
TG
« Reply #23 on: November 09, 2009, 08:23:41 PM »
I think i have a set here somewhere off an 80 GS750., look like the ones in the pic for the 400.. anyone know if they are 26mm ?
Offline rudi
« Reply #24 on: November 09, 2009, 09:15:17 PM »
Yes if they are from a Suzuki GS 750 they are 26mm Venturi . We use them to tune up a CB 400 f with 500ccm³ Powroll Big Bore Kit. It works but not without changing the Internal Parts like Needle / Jets etc.
Check in the Picture Galary cb400f.de about "Karsten Laue " and you can see the Result.....
