Author Topic: Advice needed for '73 CB350 brakes  (Read 1065 times)
Offline The Mayor
  • My Gallery
« on: November 20, 2009, 09:34:48 AM »
So I've been looking around and haven't seen anything specific to 350s, and thought I'd ask. I'm looking to maybe replace/upgrade the front brake caliper on my '73 CB350F. I've read that a caliper from a 75-76 750 will bolt on a 550 or 500? And that it's a bit bigger/better?
Question is - what are my options with the 350F if I want to swap calipers but keep the rest the same?
stevesearles
Re: Advice needed for '73 CB350 brakes
« Reply #1 on: November 20, 2009, 10:12:06 AM »
Hard to get the piston for the front caliper on this model. Honda wants $100 for the 45107-323-020 piston. Not me $$$$ >:(
Offline The Mayor
  • My Gallery
« Reply #2 on: November 20, 2009, 12:00:31 PM »
Yeah I was hoping that I might could bolt a caliper from a later CB straight on, maybe even one slightly larger (like the 750s)
Offline fletcha221
  • CENDSE BIKEWORKS
  • Cendse Bikeworks
    • OUR SHOP
« Reply #3 on: November 20, 2009, 12:16:45 PM »
Find some cb750 forks?
"Consistency is the last refuge of the unimaginative" -Oscar Wilde
1973 CB350f
1975 CB550k
1975 CB750 K5
Offline 333
  • Time for change
« Reply #4 on: November 20, 2009, 04:42:55 PM »
The problem with mixing calipers and master cylinders is that if you go with a bigger caliper, the master cylinder won't pump enough fluid to move the larger piston.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
