Author Topic: Wintergreen oil_rubber renew test / peanut oil plastic renew test_pics  (Read 82004 times)
Offline Thunder
Okay, i have always been sceptical about "easy" solutions, but this forum has been so helpful with suggestions i thought i gotta try these after reading.
basically to restore rubber use wintergreen/to restore plastic peanut butter.
I Found lotasa stuff that contains wintergreen oil(deep heat, arthritis medicine), but i want the good stuff, so off to the chemist.
After a few blank looks and phone calls they order me 15 x25ml bottles of the stuff.(biggest they had).  $15.00  375ml.
By thor7223, shot with E71 at 2009-12-03
Peanut butter was recommended, but again i want overkill, and to avoid smelling like a sandwich, Off to the health shop,+ 1 x bottle peanut oil later.
Now the test.
Peanut OIL
I have an old airbox, that the sun has had its way with
Poured some penut oil (ouderless BTW), on some toilet paper and spread over a section, to see before and after.
Waited bout n hour then wiped it off(totally DRY, nothing , even my fingers dont marr the surface as with residual oil.
. OMG? I cannot believe how freaking good this looks
Note, it seems to have penetrated the plastic as i took my fingernail and scraped the old brittle plastic i had worked on.The plastic came off (still old) BUT underneath was still the "new looking plastic".WOW, guys, thanks for that.Unbelievable.
test 2, Wintergreen oil.
My carb boots are ROCK hard. Eg, that's a 3kg weight and it doesn't even budge the rubber.
Put approx 75ml wintergreen oil  in a coffee jar and dunked the boot in up to just past the carb collar(crap pic).
Checked it out after 3 hour, nothing.
So i am gonna let it sit for 24 hour and will post the results.
to be continued...
Then i had a thought, which mebbe somebody could shed some light on.
I have a whole jar of glycerine, which i used in an effort to "restore rubber"on a '54 bmw. The rubber seems to soak it up like a sponge and its water-based.The rubber was certainly renewed, just not soft.
NOW, if i took the wintergreen and mixed with the glycerine, do you think it will draw the wintergreen into the boot, renewing it and making it flexible?... or blow me up ;D
Anybodys thought welcome
Offline GammaFlat
Re: Wintergreen oil_rubber renew test / peanut oil plastic renew test_pics
« Reply #1 on: December 03, 2009, 12:48:40 PM »
I understand you're supposed to use the wintergreen oil with xylol (available at any hardware store in the paint section).  I have both ingredients and haven't tried it yet.  Now you have me all curious.  I forget the exact mixture ratio but it is here somewhere on the forum...
Thanks for the tip on the peanut oil - My airbox is gonna get "the cure"!
K6
85 Goldwing
Offline Thunder
« Reply #2 on: December 03, 2009, 12:57:29 PM »
Yeah, gonna try get some xylol (never heard of it here ???), if i don't come right tomorrow, or if the glycerine\wintergreen doesn't work.
Offline Toxic
« Reply #3 on: December 03, 2009, 01:04:41 PM »
I feel like I am back in high school chemistry class but this time I'm paying attention.
Cool stuff.   I had never heard of the peanut oil trick.
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: December 03, 2009, 01:07:55 PM »
Simmer the carb boots in a solution of 4-8 oz Wintergreen to about a gallon of water at 200F for between 15 to 30 min.
mystic_1
- John Augustus Shedd
Offline Thunder
« Reply #5 on: December 03, 2009, 01:10:33 PM »
mystic_1
Wilco, cheers.  ;)
« Reply #6 on: December 03, 2009, 01:27:36 PM »
.....or blow me up ;D
hopefully not...but that oil of wintergreen is good aromatherapy for your bike ;D
good work, thanks for the ideas.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #7 on: December 03, 2009, 01:32:25 PM »
we get peanut oil by the gallon at wal-mart. the fryer at church uses it. i'll have to give that a try next time i pull off the airbox
Mark Twain - Notebook, 1894
« Reply #8 on: December 03, 2009, 01:38:19 PM »
:D  You'll never know if your bike will smell like turkey, twinkies or butter!  :D
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: December 03, 2009, 01:42:20 PM »
Background on Wintergreen, from http://forums.sohc4.net/index.php?topic=29707.0:
I still haven't got any wintergreen but I think its pretty much a waste of time not using it.
Yes.
Wintergreen oil absolutely does work.
The jury's still out about long-term effects, IMO, at least in terms of 5+ year time-frames.  I don't know how long people have been using this trick.  First mention of wintergreen on this board is in this post from n9viw on April 16, 2005:
http://forums.sohc4.net/index.php?topic=472.msg2914#msg2914
But it certainly works in the short term.
mystic_1
mystic_1
« Reply #10 on: December 06, 2009, 01:01:50 PM »
I worked with a guy that made custom drumsticks, he used a zylol mix to soak resin into the wood then when they dried the resin stayed in the wood making it harder and more dense. The opposite of what we are trying to do but using the same method. I think he used a vacuum source to evacuate the pores in the wood before adding the zylol mix.
« Last Edit: December 06, 2009, 01:03:47 PM by Don R »
Offline bucky katt
    • facebook
« Reply #11 on: December 06, 2009, 01:39:20 PM »
mmmmmmmmmmm twinkies
Offline Inigo Montoya
« Reply #12 on: December 06, 2009, 01:52:42 PM »
I concur on the twinkies!
Offline bucky katt
    • facebook
« Reply #13 on: December 06, 2009, 02:00:08 PM »
i havent had a twinkie in probably 10 years, dont know why
Offline JLeather
« Reply #14 on: December 06, 2009, 04:26:29 PM »
I've used the wintergreen oil before.  About 4 oz in 1/2 gallon of water or so, heat to just below a boil for 15-20 minutes.  A year later my boots are still fine to get the carbs on and off.
Offline 55fbomb
« Reply #15 on: December 06, 2009, 07:10:27 PM »
does wintergreen oil stink?  probly the dumbest question ever but i always wonder when i read this kinda stuff, lol.
or maybe im just dumb . . .
Offline GammaFlat
« Reply #16 on: December 06, 2009, 08:33:44 PM »
It does smell like chewing gum...
K6
85 Goldwing
« Reply #17 on: December 06, 2009, 09:11:42 PM »
Go eat one.
Then you'll remember why.  :D
Offline Thunder
« Reply #18 on: December 06, 2009, 09:30:39 PM »
Okay... an update... I'll post some pics when i get home. First off the wintergreen does smell like bubble gum But beware, it's got strict warnings about not ingesting it.
Finesse is not something I'm too good at, so i chucked alot of things at em.
1:I've left one boot in pure wintergreen.
2:Another i made a concoction of wintergreen and Glycerine (I'm an idiot, chemistry 101, oil n water dont mix ???)
3: One boot was left in wintergreen and alcohol
left em for a full day
I left em too long(lucky they are spare boots They have swollen to twice their size, but boy they are soft, from not being able to bend em at all, i can now easily close the carb side with thumb and forefinger.The rubber seems to now have the consistency of neoprene(wetsuit rubber).Extremely soft, however i bit a tiny piece off and it is quite weak.(i think just due to the fact it is so soft)
I read somewhere that they return to their normal shape after a while.Will keep you posted.(pics later this evening)
Conclusion: These are old remedies that actually work, and work damn well.
The peanut oil really did wonders on the grey plastic and i am now going to give it a few wax coats qand hopefully its longevity will preclude airbox pulling in a while ;D
Wintergreen:I have never seen rubber "regain" it's softness before.WOW. Hopefully they will regain shape, but lesson learnt.
« Reply #19 on: December 07, 2009, 06:09:45 AM »
How long was "too long"?  ???
I'm about to do some old ones, myself.
Offline mystic_1
  • 1970 CB750K
« Reply #20 on: December 07, 2009, 07:46:51 AM »
Eating your carburetor boots is not recommended ;)
I've heard a few times about people having issues with swelling and such when doing long-term soaks using their various alchemical admixtures, xylene+wintergreen being the most popular it seems.  I've done the wintergreen, water, and heat thing twice now and didn't have any such problems.
Anyhow yes as you say your boots may/may not return to a usable state once after sitting several days.
mystic_1
Offline Thunder
« Reply #21 on: December 07, 2009, 11:06:49 AM »
@hondaman, i think i did a bit of overkill (in the interest of science of course), i reckon go with mystic1's formula, pull em out every 10 or so minutes outta the hot water and see when they are soft enough. ;)(i left mine in 24 hours)
Its what I'm gonna do with my good set.
@Mystic1, good info, tx mate.
I haven't posted photo's, tomorrow night promise ;D
ST-DocLizard1
« Reply #22 on: December 07, 2009, 04:59:38 PM »
Good info. Time to try it out.
Doc
Offline Bakes
  • Z1 Enterprises, CS Guy, BS Artist
    • Z1 Enterprises
« Reply #23 on: January 04, 2010, 02:28:33 PM »
OK - maybe I'm stupid - if Wintergreen OIL and WATER don't mix ---------What does the hot water do for the process? ???
Would you get the same effect by 'painting' the wintergreen oil on similar to the peanut oil process? :-\
The Xylene thing I can process as the Xylene acts as a 'carrier' and then simply evaporates away leaving the wonderful, restorative, aroma-therapeutic, muscle soothing, benefits of the Wintergreen. Not to mention - apparently the boots are now also rendered edible. :o
Amazing!
Who's going to be the first to market the kit? A bottle of Wintergreen Oil, gallon of water, mama's old sauce pan, and a lighter - all for only $79.99 plus s+h.
Even more important - now that Billy Mays has died, who's going to host the infomercial?
Z1 Enterprises
Offline fmctm1sw
« Reply #24 on: January 04, 2010, 04:20:25 PM »
The same people who marketed the Y2K survival kits....
edit:  but seriously, I like this rubber restore idea...
« Last Edit: January 04, 2010, 04:23:07 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
