Author Topic: dust seal replacement  (Read 847 times)
Offline Loki
  • my bike...so far
« on: December 17, 2009, 03:58:03 PM »
ok, i did look through the faqs before i posted this, i just couldnt find it. i want to replace the dust seals on my fork, i need a walk through for it, i dont want to mess up the seals, i dont know if its easy or not. so please any one.
I don't have pet peeves, i have major psychotic f@cking hatred. - George Carlin
1977 Kawasaki kz 400
1999 Suzuki gsxr 600
1975 Honda cb 750f
1977 Honda cb 550k
Offline mystic_1
  • 1970 CB750K
Re: dust seal replacement
« Reply #1 on: December 17, 2009, 04:31:25 PM »
Do you mean the dust caps (black caps that bridge the gap between upper and lower fork) or do you mean the fork seals (seals under dust caps that hold the fluid inside the forks)?
For the dust caps, it's just remove the wheel, fender, etc, drop the forks outta the trees, pop old caps off, slide new ones on, assembly is the reverse of disassembly :)
Replacing the fork seals involves a little more work.  First, why are you replacing them?  Are you leaking fluid?  What's the state of the upper fork tubes where they slide though the seals?  Any nicks, scratches, or pits?
Replacing these involves all of the above, plus disassembling the forks themselves.  This constitutes draining the fluid, removing the upper cap, removing spring, removing the center bottom bolt that holds the damper rod in place, removing the fork seal circlip, separating the upper and lower tubes, prying out the old seal, pressing in the replacement, assembly is the reverse of disassembly ;)
Got pics?
cheers
mystic_1
- John Augustus Shedd
Offline Loki
  • my bike...so far
« Reply #2 on: December 17, 2009, 04:56:43 PM »
ya im not leaking any oil i just wanted to replace the dust seals, just was unsure of how it was properly done. thanks
1975 Honda cb 750f
1977 Honda cb 550k
