Author Topic: the coolest brakes I've ever seen  (Read 4672 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: the coolest brakes I've ever seen
« Reply #25 on: December 20, 2009, 07:44:35 AM »
that's how I showed my wife a gyroscopic force example.
except he has a fancy axle.
« Reply #26 on: December 20, 2009, 06:42:31 PM »
That makes no difference whatsoever to a gyroscope :)
mystic_1
Yes but it changes the forces as it stops it trying to twist in a different way. Also what you can't see in that demo is that if it were you holding one end of the axle that the gyroscopic effect of the wheel would be trying to break your wrist, the is a lot of twist going on. I am not going to turn this into an argument mate but those examples are quite different to a motorcycle setup that we are talking about...
  • Like a well oiled
    • Undead Asphalt
« Reply #27 on: December 20, 2009, 06:50:59 PM »
I think it's time for me to make a funny video now.
  • Like a well oiled
    • Undead Asphalt
« Reply #28 on: December 20, 2009, 07:27:46 PM »
ok here it is!
I watched it twice and I'm still laughing at myself.
« Last Edit: December 20, 2009, 07:29:20 PM by Industrial Cafe »
« Reply #29 on: December 20, 2009, 07:33:58 PM »
 ;D ;D ;D ;D   Told you there was some twist going on..... :o
  • Like a well oiled
    • Undead Asphalt
« Reply #30 on: December 20, 2009, 07:36:38 PM »
hahaha, yeah it's not much, you can easily hold it straight.
but like you said, it doesn't have much to do with the disc setup.
I have a drill with a miniature of that planetary gear setup in it, maybe I'll do some experiments.
Offline mystic_1
  • 1970 CB750K
« Reply #31 on: December 20, 2009, 11:19:42 PM »
The physics of gyroscopes is unaffected by how the axle is mounted.  The mounting of the axle will change how the forces are transmitted to other objects, but the underlying physics don't change.  If you believe that gyroscopic precession doesn't occur in a motorcycle due to the fact that the axle is mounted at both ends, you're mistaken.
Now, whether all this plays a role in the brake design originally posted, unless the rotating rotors equal the mass of the rest of the wheel, they're not going to be imparting a whole lot of force by comparison.  Can't imagine it's worth the added cost, weight, and complexity.
mystic_1
- John Augustus Shedd
« Reply #32 on: December 21, 2009, 12:32:19 AM »
I think you need to read between the lines a little Mystic because that is not what i said at all. Look at my examples or IC's video that is what i said. The forces in your examples are different to what i have said because the forks nullify it to a degree by stopping or reducing the Twist by anchoring both sides of the wheel, thats the difference between what you posted and what i was saying. Getting back to the original theme of the post, the reverse spinning discs won't eliminate the gyroscopic effect but they will lessen it, therefore helping the bike steer easier and also making it easier to flop from left to right in corners. You said..."I don't buy the minimizes gyroscopic effect" and that is what i am saying is wrong, it will minimize the effect, not stop it, but definitely minimize it,  the counter rotational forces of the disc are part of the spinning wheel, therefore acting against the forces of the wheel.....its that simple. Another example, the gyro effect of the wheel traveling forward wants to twist the wheel to the left, the discs want to twist to the right,so the forces are pulling against each other reducing the effect of the dominant force which in this case would be the wheel. This is why Motor cycle manufacturers and race teams have been trying these systems out for over 30 years, it works but it isn't used because of the added unsprung weight.
Ok Just did some reading on the physics of gyro's, This is from a physics site.
Gyro's rotating in opposite directions means that some or most of the effects of precession will oppose and cancel out, giving a platform that is more stable than two gyros rotating in the same direction.
torque = dL/dt
where L is the angular momentum of the gyroscope.
The total angular momentum, L, of a pair of counter-rotating gyroscopes is zero. Thus a system with a pair of counter-rotating gyroscopes rigidly joined together will act just like a system with no gyroscope.
« Last Edit: December 21, 2009, 02:18:54 AM by retro rocket »
Offline mystic_1
  • 1970 CB750K
« Reply #33 on: December 21, 2009, 04:59:15 AM »
I still think you're misunderstanding precession.  A spinning wheel does not "want to twist", in fact, quite the opposite!  Gyroscopic precession occurs when you try to turn the spinning wheel, the wheel will want to twist at an angle different from the applied input  For example, twisting the wheel around a vertical axis will cause the wheel to want to lean vertically.
Precession is NOT the tendency of a gyroscope to maintain it's alignment, but rather the change in vector when you try to change the gyroscope's orientation.
The second quote you posted is immediately followed by the following sentence:
Note that the joining must be rigid. Large forces can be generated in the process of attempting to change the orientation of a such a pair of gyroscopes quickly, which could break the joining if it were not strong enough.
If all forces were canceled, where would the "large forces" come from that could break the axle?
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #34 on: December 21, 2009, 09:01:33 AM »
mystic_1
Need to drink more coffee before posting in physics-related threads :)  Understand that both gyroscopes try to precess in opposite directions, that's what breaks the axle.
Still, don't think the axle mounting has anything to do with the way forces are generated in these systems, just how the forces are transmitted.
Man, now I want to build a big counter-rotating gyroscope out of spare front 750 wheels and run some experiments :D
mystic_1
  • Like a well oiled
    • Undead Asphalt
« Reply #35 on: December 21, 2009, 09:10:59 AM »
I'm gonna try to do it on a bicycle wheel scale.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #36 on: December 21, 2009, 10:45:19 PM »
as i understand it, the gyroscopic effects of the rear wheel are desirable, as this is what keeps the bike upright, but such an effect on the front wheel is unnecessary, and a lessened gyroscopic effect could ease steering, as the wheel would not being trying as hard to stay perpendicular to its rotating axis.
real world examples: watch GP riders wheelie out of turns... the bike maintains it's stability, because of the balance of the rider's center of gravity leaning into the turn and the gyroscopic effect of the rear wheel under power that is trying to return itself to upright. the front wheel is unnecessary in terms of gyroscopic stability. if the primary goal of the front wheel as a steering component is independent of the bike's need for gyroscopic stability, then it seems to me that moving that spinning wheel about would be easier without fighting this force.
« Last Edit: December 22, 2009, 09:29:19 AM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mec
« Reply #37 on: December 22, 2009, 12:00:39 AM »
to complicate things furthermore:
maybe unknown to one or the other, activating the FRONT brake during a wheelie can prevent from backflip.
with the counterrotating rotors this positive effect is minimized or not present at all dependent on the relationship of rotor rpms and weight (in comparison to wheel rpms and weigth).
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline paulages
  • 1976 cb735
« Reply #38 on: December 22, 2009, 09:33:41 AM »
mec
that's not too surprising to me actually, as the energy (inertia) from the spinning wheel has to go somewhere if the brakes lock the wheel up. maybe i'm thinking about it wrong, but it seems like this would try to throw the wheel forward a little.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
  • Like a well oiled
    • Undead Asphalt
« Reply #39 on: December 22, 2009, 09:35:06 AM »
doesn't the stopped front wheel cause a tank slapper when it comes down from a wheelie, or is it the accidental misalignment of the front and rear tire?
Offline 6pkrunner
« Reply #40 on: December 24, 2009, 04:28:20 AM »
Any item rotating around a centrally mounted point will have a gyroscopic effect. Plain physics. The trick is to convince someone that this is a bad thing and then get them to spend ridiculous amounts of cash to try to make it better or lessen the effect.
The guy with the counter rotating brakes spent a huge amount of money for a few percentage points of change. He started off at the point of diminishing returns and went from there. The only sad part may be that the masses think this is a great idea and it becomes standard are on bikes and adds hugely to the cost.
  • Like a well oiled
    • Undead Asphalt
« Reply #41 on: December 24, 2009, 06:38:29 AM »
The unnecessary product you never knew you needed.
they still look cool.   all twirling around the wrong way.
Offline MickeyX
« Reply #42 on: December 25, 2009, 04:00:56 PM »
OMFG, another dyna beads thread.
 ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #43 on: December 25, 2009, 04:54:26 PM »
bwaaah
Offline paulages
  • 1976 cb735
« Reply #44 on: December 25, 2009, 05:35:32 PM »
for the record, i wasn't endorsing this at all, just discussing why a person might want less gyroscopics on the front wheel.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Zaipai
    • My Home page
« Reply #45 on: December 27, 2009, 02:35:18 PM »
An interesting read none the less.. I will be having my step son read this his major is in physics.
Its my Avatar..
75 CB550F  |
