Author Topic: 550 fork tubes in 750 lowers  (Read 818 times)
Offline 55fbomb
« on: January 03, 2010, 05:40:10 PM »
what is the difference between 550 and 750 fork tubes?  can 550 tubes be used in 750 trees and lowers? are 550 tubes shorter than 750s?  i need undersized fork tubes at least 1 under prefer -2s, and cycle x is out and has been out for a while and i dont have $250 laying around for Franks tubes, thanks everyone.
or maybe im just dumb . . .
Offline 55fbomb
Re: 550 fork tubes in 750 lowers
« Reply #1 on: January 03, 2010, 08:17:54 PM »
nobody knows the answer to any of these questions?  anyone know where i can find this information?
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: January 03, 2010, 08:26:04 PM »
you would have to use the valve body out of the 550 and the tubes of a 550 in the lowers of a 750. the seals are the same cause they're both 35mm, but the inside is different.
also, using 750 springs will stiffen up your ride on the 550.
the stock 550 tubes are just a bit shorter, like maybe an inch or 2.
I think... don't quote me on that last part.
Offline 55fbomb
« Reply #3 on: January 04, 2010, 06:23:09 AM »
Ok, thank you. maybe i will just use the lowers from the 550 with my springs and a 550 disc on my wheel, or just wait till cycle x gets tubes again, thanks again.
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: January 04, 2010, 07:02:28 AM »
what are you trying to do?  why would you use a 550 disc on your 750?
Offline 55fbomb
« Reply #5 on: January 04, 2010, 07:08:54 PM »
someone told me that the caliper wont line up with the rotor if i use a 750 wheel in 550 lowers because the 750 disc is larger or something, i got a line on a set of 550 forks so i guess i will find out.
« Reply #6 on: January 04, 2010, 07:14:30 PM »
Front hubs are the same, just use the 550 disc.
Offline 55fbomb
« Reply #7 on: January 04, 2010, 07:21:31 PM »
so with the different valve stuff, i cannot use just the 550 tubes then right?  i wouldnt have thought about that, i woulda just done it, thanks for all the info.
