Author Topic: Centering a drum brake plate.  (Read 8510 times)
« on: January 04, 2010, 09:34:23 AM »
I got this from RaceTech.com. I had them "arc" the rear brake on my Phaedrus projet, CB750K2. That is an old art of first turning the brake drum on a brake lathe. Then grinding the brake shoes to match the arc of the drum for maximum contact.
But to the subject of this post, anyone can center their brake plate when installing. You should tighten the axle only a bit. Then engage the brake either by hand or have someone step on the pedal. This will center the brake plate, taking up any of the slack clearance it may have between it and the axle. While the brake is engaged, tighten the axle.
If yours was off, this can improve the feel and power of the drum brake, reducing fade, and potential of glazing the shoe at a hot spot.
Re: Centering a drum brake plate.
« Reply #1 on: January 23, 2010, 08:31:35 PM »
Been doing that for years, works great..
Offline Zaipai
    • My Home page
« Reply #2 on: January 23, 2010, 08:35:54 PM »
This is some thing I did not know. I will do this for sure during the putting back to gether phase!
Thanks!!!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Steve F
« Reply #3 on: January 27, 2010, 06:43:13 AM »
I'm so glad I have disc brakes...... ;D
« Reply #4 on: January 27, 2010, 08:36:08 PM »
Oh yeah, wait till you get;
 stuck piston...
 pitted piston...
 dragging piston..
 Warped or dished rotor..
 pull your front brake lever back to the throttle grip, when wet & it does not even slow down....
 get some nice Dot 3 on your paint..
 etc..
Offline Steve F
« Reply #5 on: January 28, 2010, 04:26:05 AM »
 stuck piston...
 pitted piston...
 dragging piston..
 etc..
Been there...Done ALL that and still glad I have disc. ;)  Drilled rotors..not problem in the wet, pistons new in stainless steel..."last long time",  rotors still good after 30k miles,  DOT3 on the paint??? don't YOU have a front disc too?
« Reply #6 on: January 28, 2010, 09:28:52 AM »
Yup, I do.. run dot 5 usually, is it dragging yes.. >:(
 I dont dislike my rear drum enough to change it, but will eventually go disc to be able to build a really light wheel.
 If the only way to have a rear disc on a 750 was to run a comstar, I would never run one..
 I was just pinting out though that discs are not trouble free, and can have more problems than drums after sitting for a few years..
Offline Steve F
« Reply #7 on: January 28, 2010, 09:44:37 AM »
Oh, I agree with you on not being trouble free, anything mechanical is gonna eventually have troubles.  I also agree about the Comstars...some like 'em, some don't and I prefer the wire spokes on the '75-'76F's.
