Author Topic: Stiffer clutch springs into CB360, possible?  (Read 5541 times)
Saml01
« on: January 06, 2010, 04:58:06 PM »
Is there any way I can install stiffer clutch springs into my CB360?
Are they available aftermarket or do I have to find a bike with similar springs? If so, which can I use?
Saml01
Re: Stiffer clutch springs into CB360, possible?
« Reply #1 on: January 22, 2010, 04:59:21 PM »
guess not
James360
« Reply #2 on: January 23, 2010, 12:35:20 AM »
www.shspowersports.com   has the OEM honda part numbers for 360s and the earlier 350s, both show to use the same 4 clutch springs part # 22401-323-003
www.bore-tech.com shows to have what they call heavy duty clutch springs for the 350s $14.95
if you google "Todd Henning Racing" they have Barnet racing clutch parts for the 350, springs, discs, plates, clutch basket.
Pretty sure Barnnet is the racing clutch company been making clutch stuff for harleys forever. well respected clutch company.
« Last Edit: January 23, 2010, 02:03:50 AM by James360 »
Offline TomC
« Reply #3 on: January 23, 2010, 06:41:48 AM »
Hi James360
     The part number you list is for a CB500 Four clutch spring. Barnnet lists springs and other parts for the 350 twin but I think only plates for the 360 twin. I expect that Barnnet would know if the 350 twin and 360 twin clutch springs were the same. If I need to look at the clutch on my cb350K4 I will compare the springs with some CB550 Four clutch springs.
    TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #4 on: January 23, 2010, 08:03:37 AM »
EBC sells stiffer clutch springs. But my experience with them is they're too strong for comfort in everyday use. An easy way to go is just install an additional 6mm washer under the head of each pressure plate bolt. That'll add preload to the springs. Don't do only half of the bolts; you don't want uneven loading on the pressure plate.
Stu
MCN DTF
James360
« Reply #5 on: January 23, 2010, 08:58:28 AM »
Hi James360
    TomC in Ohio
Hello tomC
I looked at the shs power sports OEM honda part numbers for a 1970 CB 350 it shows 22401-323-003 for the springs, I looked up a 1975 CB 360 same clutch spring part # 22401-323-003, honda obviously carried over the clutch springs from the earlier 350s to the 360 model. this is why i gave him the shs power sports web site so it could be looked up. I have no doubt these same 22401-323-003 clutch springs could have also been used in other models without looking them all up.
if you look at the www.shspowersports.com web site i gave saml01 you can see the 350 and 360 using the same part number spring, so any of the racing 350 clutch springs should fit, or he can take chickenman's recomendation.
Seems like in looking for parts somewhere for my 360 that someone mentioned CB550 springs are a little stiffer fit 350 honda's, but i'm not sure on this.
« Last Edit: January 23, 2010, 09:27:50 AM by James360 »
Offline TomC
« Reply #6 on: January 23, 2010, 07:12:12 PM »
Hi James360
     I question shs power sports listing! That is a part that was first used on a 500 Four. As the 350 Twin precedes the 500 Four if the Honda parts numbers were the same the 500 Four would use a 350 twin part number. I checked my 550 parts list and the 550 used a different part number clutch spring.
     How different are these springs? I would like to know. The best way is to compare actual springs.
     TomC in Ohio
TomC in Ohio
« Reply #7 on: January 23, 2010, 07:51:55 PM »
Part # = 22401-323-003
Part Description = SPRING, CLUTCH - (replaces 22401-275-000)
Model Count = 35
CB350 1968 350 Super Sport 350 Street
CB350G 1973 350 Super Sport 350 Street
CB350-K2 1970 350 Super Sport 350 Street
CB350-K3 1971 350 Super Sport 350 Street
CB350-K4 1972 350 Super Sport 350 Street
CB360G 1974 360 CB360G Street
CB360-K0 1974 360 CB360 Street
CB360T 1975 360 CB360T Street
CB360T-76 1976 360 CB360T Street
CB400F 1975 400 Super Sport 400 Street
CB400F-76 1976 400 Super Sport 400 Street
CB400F-77 1977 400 Super Sport 400 Street
CB500 1971 500 500 Four Street
CB500-K1 1972 500 500 Four Street
CB500-K2 1973 500 500 Four Street
CB550-K0 1974 550 550 Four Street
CB72 1961 250 Hawk 250 Street
CB750F-K5 1975 750 750 Super Sport Street
CB750F-K6 1976 750 750 Super Sport Street
CB750-K6 1976 750 750 Four Street
CB750-K7 1977 750 750 Four Street
CB750-K8 1978 750 750 Four Street
CJ360T-76 1976 360 CJ360T Street
CJ360T-77 1977 360 CJ360T Street
CL350 1968 350 Scrambler 350 Dual Sport
CL350-K2 1970 350 Scrambler 350 Dual Sport
CL350-K3 1971 350 Scrambler 350 Dual Sport
CL350-K4 1972 350 Scrambler 350 Dual Sport
CL350-K5 1973 350 Scrambler 350 Dual Sport
CL360 1974 360 Scrambler 360 Dual Sport
CL360-K1 1975 360 Scrambler 360 Dual Sport
CL72 1962 250 Scrambler 250 Street
SL350 1970 350 Motosport 350 Dual Sport
SL350-K1 1971 350 Motosport 350 Dual Sport
SL350-K2 1972 350 Motosport 350 Dual Sport
MCN DTF
Offline TomC
« Reply #8 on: January 23, 2010, 08:07:47 PM »
HI chickenman_26
     Looks like Honda has decided to use the 500 Four clutch spring to replace many different part numbers.
     I checked Barnett clutch's web site. They now list a spring set for the CB360. Which is the same as the spring set for the Cb350 Twin. Also the CB400 Four. The CB400 Four used CB360 Twin Clutch Spring #22401-369-000. Barnett's does not list a spring kit for the 500 Four.
     Does any one know what model 275 is?
     TomC in Ohio
TomC in Ohio
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #9 on: January 23, 2010, 08:17:43 PM »
   Imagine that, chickenman beat to posting this that I found on croctchrocket.com
     2401-275-000    View Sku Supersession
Loading...
CB350 A MOTORCYCLE, JPN, VIN# CB350-1000001
Assembly: CLUTCH
   SPRING, CLUTCH (Honda Code 0038547) (SKU: 22401-275-000) (Supersede: 22401-323-003)    4    $4.65    Add to Cart        [Click to view details]
22401-275-000    View Sku Supersession
Loading...
CB350G A MOTORCYCLE, JPN, VIN# CB350-5000001
Assembly: CLUTCH
Loading...
CB350K2 A MOTORCYCLE, JPN, VIN# CB350-2000001
Assembly: CLUTCH
Loading...
CB350K3 A MOTORCYCLE, JPN, VIN# CB350-3000001
Assembly: CLUTCH
Loading...
CB350K4 A MOTORCYCLE, JPN, VIN# CB350-4000001
Assembly: CLUTCH
Loading...
CB360 A MOTORCYCLE, JPN, VIN# CB360-1000001
Assembly: CLUTCH
   SPRING, CLUTCH (Honda Motorcycle Code 0038547) (SKU: 22401-275-000) (Supersede: 22401-323-003)       $4.65    Add to Cart        [Click to view details]
Loading...
CB360G A MOTORCYCLE, JPN, VIN# CB360-1000001
Assembly: CLUTCH
Loading...
CB360T A MOTORCYCLE, JPN, VIN# CB360-2100001 TO CB360-2123938
Assembly: CLUTCH
Loading...
CB360T A (76) MOTORCYCLE, JPN, VIN# CB360-2200001
Assembly: CLUTCH
Loading...
CB400F A MOTORCYCLE, JPN, VIN# CB400F-1000006 TO CB400F-1038492
Assembly: CLUTCH
Loading...
CB400F A (76) MOTORCYCLE, JPN, VIN# CB400F-2000001 TO CB400F-2008280
Assembly: CLUTCH
Loading...
CB400F A (77) MOTORCYCLE, JPN, VIN# CB400F-2100001 TO CB400F-2104166
Assembly: CLUTCH
Loading...
CB500 A MOTORCYCLE, JPN, VIN# CB500-1000001
Assembly: CLUTCH
Loading...
CB500K1 A MOTORCYCLE, JPN, VIN# CB500-2000001
Assembly: CLUTCH
   SPRING, CLUTCH (Honda Code 0038547) Use up to Engine SN 2112144 (SKU: 22401-275-000) (Supersede: 22401-323-003)    4    $4.65    Add to Cart        [Click to view details]
Loading...
CB500K2 A MOTORCYCLE, JPN, VIN# CB500-2100001
Assembly: CLUTCH
Member # 1969
« Reply #10 on: January 24, 2010, 08:21:29 AM »
Imagine that? I don't understand why you're surprised.   ???  All I did was type the part number into my Zedder cross reference software and posted the result.
Stu
« Last Edit: January 24, 2010, 08:24:28 AM by chickenman_26 »
MCN DTF
James360
« Reply #11 on: January 24, 2010, 01:36:21 PM »
Stu
   Who is this EBC company. I replaced all my clutch parts with OEM parts including the springs. Was kind of wanting some stiffer springs i'm really just using my bike as mild trail bike, hill climber. but i'm considering souping the engine up pretty good.
« Reply #12 on: January 24, 2010, 04:48:50 PM »
Excellent brake and clutch products. http://www.ebcbrakes.com/Index.html
Their catalog shows the clutch spring kit for your 360 as their part #CSK4. Any bike shop should be able to order for you from the catalog.
Stu
MCN DTF
James360
« Reply #13 on: January 24, 2010, 07:42:17 PM »
Stu
Ok thanks will check it out.
Offline bill440cars
« Reply #14 on: January 24, 2010, 08:52:15 PM »
Stu
     That's what I did, at crotchrocket.com, but you were faster than I was. (I wasn't trying to outdo you) I was just sitting there holding that Info, saw that YOU had already done it and thought that, maybe there was something that mine might have covered, that your's didn't. No offense intended, just hated to not do something with what I was holding, that's all. ;)
Member # 1969
« Reply #15 on: January 25, 2010, 06:16:04 PM »
...just hated to not do something with what I was holding, that's all. ;)
Nah...I'm not going there!  ;D
Stu
MCN DTF
Offline bill440cars
« Reply #16 on: January 25, 2010, 06:52:58 PM »
Stu
           Seems like a Good choice. ::)
Member # 1969
Offline freedomgli
« Reply #17 on: May 12, 2014, 02:20:51 PM »
Thanks for the feedback. I fitted stiffer clutch springs from Bore Tech a while back on my long-term CB350K racer project. I don't know if they're EBC or not and I never measured their spring rate but I trust Bore Tech sells a quality product. I have since modified my clutch lifter assembly by retrofitting a Suzuki GT250 worm gear type mechanism. While putting it all back together I was astonished by how much effort was needed at the hand lever and I feared that my new clutch lifter was the culprit. But then I remembered the springs. Now I'm thinking about going back and fitting my original clutch springs to see if that  solves my problem. Otherwise I'm going to need some major left hand strength training!
