Author Topic: i have 4 into 4 pipes with no baffles  (Read 1635 times)
631girl
« on: January 17, 2010, 04:15:59 PM »
the carbs are stock. that i know off. will it run lean, im thinking yes.. if so does anyone know what to do..to get it back to norm.  it sound good and people can hear me.. thats is beter, loud pipes save lives in my book..
here is a pic so far
if would like to see more pics go here..
http://forums.sohc4.net/index.php?topic=63553.msg693621#msg693621
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: i have 4 into 4 pipes with no baffles
« Reply #1 on: January 17, 2010, 07:22:36 PM »
you're gonna have to jet the carbs, it's subjective from motor to motor.
z1enterprizes has the round jets for cheap.
nice front end. ;D
« Reply #2 on: January 17, 2010, 08:39:46 PM »
 Big T-T-t-tire...................... :o
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: January 17, 2010, 08:44:54 PM »
Of bigger concern is your intake system.  There's none in the pic, what do you plan to run?  Pods?  Stacks?  Breadbox?  Airbox?  Nothing??  This decision has a much more direct impact on your jetting than the exhaust.
mystic_1
- John Augustus Shedd
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: January 17, 2010, 08:58:16 PM »
+1
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: January 17, 2010, 10:25:53 PM »
I'd say to buy 3 sets, graduating up from what's in there now.
you'll have to experiment with it till it's right.
that's what I did.
Offline Old Scrambler
« Reply #6 on: January 18, 2010, 07:21:07 AM »
If you want to quiet the pipes a bit.........it may be cool to use the old Snuff-r-Nots.  They are spring-mounted washers that can be turned flush to create some back-pressure.....or turned open to allow the full bravato of the motor.  Others have inserted short baffles removed from mufflers taken from older model twins.
Your jet sizes will likes fall in the 115 - 120 - 125 range for street cruising with a stock motor.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Hinomaru
« Reply #7 on: January 18, 2010, 07:58:12 AM »
The old Snuff or Nots are available as a reproduction item.  ;D
http://www.honda305.com/cb77_800/cb77-818.htm
Some Harley riders use a similar "washer" method on their drag pipes:
http://www.nightrider.com/biketech/exhaust.htm
Offline nobody
« Reply #8 on: January 18, 2010, 02:13:47 PM »
is it neeeded or just the bike looses lowend..using cone fiters
I haven't tried switching my bike to the airbox to see how much they actually differ yet. My 74k has cones and it makes next to no power until I get above three thousand RPMs. From three thousand on up to redline it pulls hard but it's mostly lifeless before that. I've read here that a 750 using the airbox will pull harder for much more of the RPM range. I intend to switch but need to finish rebuilding my transmission before I can even consider that undertaking
74 cb750k
