Author Topic: Rear drum brake noise?  (Read 2172 times)
Offline egor
  • I love bacon!
« on: February 02, 2010, 12:02:00 PM »
Would rear drum breaks on a cb550 make any noise....when the bike is in motion but the brakes are not being applied?
04' Ducati Monster 620ie (sold)
75' CB550f Super Sport
Markcb750
Re: Rear drum brake noise?
« Reply #1 on: February 02, 2010, 12:05:20 PM »
sure, especially if something is wrong like adjusted too tight.
what are you hearing?
Offline Deltarider
« Reply #2 on: February 02, 2010, 12:10:11 PM »
No. What kind of sound? Is your model equipped with a brake wear indicator? If it doesn't sound like iron on iron, why not experiment a little with the adjustment?
CB500K2-ED Excel black
Offline Johnie
« Reply #3 on: February 02, 2010, 12:11:38 PM »
Wheel bearings???
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline egor
  • I love bacon!
« Reply #4 on: February 02, 2010, 12:14:23 PM »
Its not a squeel, like the front brakes usually make on these bikes.
Only hear it when in motion.  Light scrape sound from the back area of the bike.  Not very loud.  Not a constant scrape sound. Sound gets faster or slower depending on bike speed.
Not the shocks, probably not the chain, not the tire, not the swing arm.  Think it would have to be the brake.
« Reply #5 on: February 02, 2010, 12:19:12 PM »
HAs it been sitting for a while? Gunk build up is now sluicing around with the brake shoes.
Back off the adjuster as much as is safe and see the difference.
In any event, I vote for simple dirty build up of brake shoe dust and gunk. Disassemble and while standing outside, blow it out (hub and backing plate) with air. Do not do it inside. Maybe wear a dust mask.
Wipe the drum off with alcohol or such. Don't touch the shoes with anything, fingers especially.
Just an FYI: I've never seen a Honda MC shoe wear down to the shoe. Just too much material on them. So that's not likely.
Could be bearings too.
« Last Edit: February 02, 2010, 12:21:20 PM by MCRider »
Markcb750
« Reply #6 on: February 02, 2010, 12:20:03 PM »
Could be a bearing or a brake.
Put the bike on the center stand and slowly rotate the rear wheel, a notchy feel indicates a bearing. brake drage will not have the notch feel....
Usually, most of the time.
Offline xenoscr
  • 1975 Honda CB750 K5
« Reply #7 on: February 02, 2010, 12:21:14 PM »
1975 Honda CB750 K5
Offline egor
  • I love bacon!
« Reply #8 on: February 02, 2010, 12:25:34 PM »
Good test...thanks guys.
Offline Deltarider
« Reply #9 on: February 02, 2010, 12:44:55 PM »
Are you sure it's not the chain?
