Author Topic: found a parts bike  (Read 2208 times)
Offline bikeme2001
found a parts bike
« on: March 05, 2010, 04:11:29 AM »
I found a 78 750 f,I have a 78 750 f I'm restoring.The motor in the parts bike is frozen and when I drained the engine oil it looked a clear substance similer to water.I'm just wondering if the motor is worth pulling apart or do I just scrap the thing.I don't want to spend a bunch of time to find out its all junk.I did strip the frame and paint.Ill use the frame on a cafe bike later.And I did get a bunch of plastic and both wheels, forks, front and rear brake rotors and complete rear brake system.I need all this stuff for my restore project.Any hope for the motor?
Offline KB02
Re: found a parts bike
« Reply #1 on: March 05, 2010, 04:45:23 AM »
I turned a frozen motor into a runner, so it can be done. If you don't need it right now (planning on using the other motor you have), I say pout it aside and tear it down later. Might be some useful bits in there that you can sell o ebay or maybe make a built up motor once you have the bike running with the stocker.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline the architect
« Reply #2 on: March 05, 2010, 06:14:14 AM »
A friend of mine freed up a siezed motor by pulling the head and filling the cylinders with some amount of diesel fuel.  Over about a week's time, it penetrated the areas that were fused and the thing ran.
Clear oil.  Reminds me of that clear Crystal Pepsi, from back in the day.   ;D
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
Offline bikeme2001
« Reply #3 on: March 05, 2010, 11:06:03 AM »
Yea, the thing was full of water,
Offline mgbgt89
« Reply #4 on: March 05, 2010, 11:12:57 AM »
Acetone and ATF mixed in a 50/50 solution will free a stuck engine, or so i've heard. It supossedly is better than any off the shelf rust penetrant.
« Reply #5 on: March 05, 2010, 11:33:18 AM »
There is an engineering type report on the forum somewhere that confirms this. I'd mix some up, squirt it down each plug hole wait a day and see.
In any event, I wouldn't "scrap" it, sounds so final. Someone is interested in a whole motor seized or not. The alternator is valuable, if low mileage the trans is valuable, etc. Even people need whole cases sometimes when theirs are broken.
Being a dry sump motor one wouldn't expect much oil in it. The water could have come from condensation which is generally what rusts them up any way, just sitting around. In a cold shed outdoors or such, temp changes causes condensation.
Not necessarily or even probably malicious abuse.
« Last Edit: March 05, 2010, 11:35:51 AM by MCRider »
Offline bikeme2001
« Reply #6 on: March 05, 2010, 07:22:34 PM »
I have soaked the engine with fluid film,I will get some acetone and AFT later.I'm hooked on these bikes though.Seems cool to be able to get a bike for next to nothing and find all kinds of pieces that you need and to be able to start an other project along the way.
Offline kerryb
  • Not a very
« Reply #7 on: March 07, 2010, 09:32:37 PM »
I got a parts bike with what seemed like a seized motor ('78k).  During disassembly, I found it would spin backwards and forward through about 340 degrees.  The problem was rust right at the top of a cylinder so it couldn't go through top dead center.  You may have more possibilities than you think.
