Author Topic: which cylinder head is better?  (Read 1438 times)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« on: March 11, 2010, 12:50:57 PM »
i have the original head off of the k6 750 motor and i also have 2 heads from cb750f's a 1975 and a 1976. which one am i better off starting a port job with? i'll be replacing guides as well, and valves if theyre worn too much. this is a mostly stock motor with a 3rd overbore (755cc's) i'm going to have around .020 milled off the deck surface in addition to cleaning up the ports and ccing the chambers. i'll be running a 1977 cb750f cam with points and a hondaman ignition (man i love being able to type that...hondaman ignition  ;D ) and a kerker pipe at the moment, going to either a cyclex 4-2-1 or a carpy pipe (probably the cyclex pipe)
« Last Edit: March 11, 2010, 02:23:39 PM by bucky katt »
Mark Twain - Notebook, 1894
Offline Old Scrambler
Re: which cylinder head is better?
« Reply #1 on: March 11, 2010, 01:22:20 PM »
I am not aware of any changes to those years..........check the rockers/shafts and reload as a complete unit in correct order.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bucky katt
    • facebook
« Reply #2 on: March 11, 2010, 02:20:12 PM »
i was thinking that maybe the f head might have better ports, i need to decide which one i'm going to re-work
Offline eurban
« Reply #3 on: March 11, 2010, 04:14:37 PM »
76K and F heads are different.  The pre 77Fs and the 77/78ks have a redesigned head with a more "hemi" shaped combustion chamber.  They should flow better stock than your 76K head although there can be a bit of range in the quality of the factory work on any given head.  Most likely the pre 77f heads will be your best bet . . .
Offline bucky katt
    • facebook
« Reply #4 on: March 11, 2010, 04:31:09 PM »
excellent, i'll start tearing the f head down tomorrow, checking clearance between valve and guide, see what kind of condition the seats are in. if i'm lucky i wont have to do guides or valves then all i'd need to do on that end of things is polish the valves right under the head. i have a large cache of carbide cutters and sanding flap wheels for the 1/4" air die grinder, my cc kit from when i built air cooled vw heads and then the putty to check valve clearances after i get the head milled with the 77f cam.
