Author Topic: K1 750 Restoration - Engine questions  (Read 3119 times)
Offline mwvachon
  • The Family Heirloom
« on: January 18, 2006, 03:32:04 PM »
Hi All,
Beginning to tackle the engine on my resto project. The top-end was rebuilt about six or eight thousand miles ago (but about 20 years ago!) Even then, the mechanic asked why I had him do it (about 28K showing on the odo at that time) - he reported all parts appeared to be in great shape. The main reason I had him do it was a slight oil weeping in the head. He replaced the cam rollers, checked the valves and put in the new top-end gaskets. Bike has always run great, no issues relative to the inner workings.
I scoured the forum posts for information on head gaskets & leaks - this one does have some slight weeping between the two cylinders on the point-side of the engine now. My question is relative to the oil weeping. I have no reason to believe there is a need to tear down the top-end, although I'm taking the valve cover off to polish it up. Wondering if I'll be all set with just re-torquing the head?
Ideally, I'd like to just clean up the cases, polish the covers, touch up the silver-painted areas, and just put it back together. I do need to inspect the clutch, had some issues with jerky starts in 1st gear just prior to starting the restoration. But other than that, I believe the motor is solid. Can anyone comment on this line of thinking? (please be nice  ;) ) Thanks to all in advance for your usual great input...
M.W.Vachon
2014 CB1100 Deluxe
1999 Valkyrie I/S
1971 CB750-K1 (Candy Gold)
1971 CB750-K1 (Candy Red)
Project link: http://forums.sohc4.net/index.php?topic=108498.0]
1965 Honda S90
1976 GL1000
1975 CB400F
Offline volz1fsu
Re: K1 750 Restoration - Engine questions
« Reply #1 on: January 18, 2006, 06:41:56 PM »
You can always try to re-torque a head to seal a gasket.  You MUST heat the engine to operating temperature to accomplish anything this way.  Many engines with aluminum heads recommend re-torquing the head bolts after warming up the engine to seal a new gasket.  It might work for you but then again the head may be warped and leaking because of it. Hopefully not in your case.
« Last Edit: January 18, 2006, 06:43:41 PM by volz1fsu »
Offline Clyde
« Reply #2 on: January 18, 2006, 07:04:25 PM »
It would certainly be worth re-torqueing the head once the engine is out, but you need to make sure where the leak is coming from.
I re-torqued a head and it still leaked as the rubber button seals under the cam boxes were leaking not the head gasket. A pain as you have to pull these engines out to do anything with the top end.
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline volz1fsu
« Reply #3 on: January 18, 2006, 07:19:28 PM »
Does the Engine really have to come out on a 750 to do top end work?  I can do head work on my 550 with the engine in the frame.
« Reply #4 on: January 18, 2006, 08:03:33 PM »
It all depends on much you hate an oil leak. You will have to pull the engine to even retorque, and quite frankly that probably won't eliminate your leak. It's the o-rings between the cylinder & head that generally cause the problem, so if you absolutely have to cure the leak, remove the top end, clean all gasket surfaces very well (be careful not to gouge the aluminum) and install new head and cylinder base gaskets. I have read that people have tried teflon o-rings to replace the original as they might withstand the heat better, but someone else will have to let us know about that as I haven't used anything but what's in the kit. When it's apart, do a close inspection but it doesn't sound like you'll need to call the parts man for many replacements!  Good luck.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: January 18, 2006, 09:09:32 PM »
Short answer, yes.  Long answer, yeeeeeeessssss. ;D
« Reply #6 on: January 19, 2006, 08:10:40 AM »
Alloy heads are re-toqued COLD cast heads HOT and Honda dont specify a re-torque anyway BUT do make sure that the nuts spin free on the studs as any binding  will alter the torque
Offline Lumbee
    • My pics...
« Reply #7 on: January 19, 2006, 01:54:49 PM »
...it being such a pain to pull these motors I'd say spend $20 and just put a new gasket in it.  I imagine you won't be happy if you only retorque, get everything back together and you still have the leak on your freshly polished motor...   :'(
"I'm not a welder, but I play one on HondaChopper.com"
Offline Clyde
« Reply #8 on: January 19, 2006, 02:50:02 PM »
If the leak is clearly from the cam box rubber o-rings/buttons, I would not touch the head gasket, except for re-torqueing.
It is a quick job to take the cam towers out and replace the o-rings/buttons. (Once that engine is out of the frame that is)
The parts are not too expensive either.
Regds Clyde
SOHC4 #1909
Offline mwvachon
« Reply #9 on: March 12, 2006, 06:27:55 PM »
Additional question - Anyone got a list of torque specs for the CB750's? I have 2 shop manuals and only the older one lists a torque spec here & there (they at least saw fit to print the head bolt pattern and torque). My Valkyrie shop manual provides torques for almost every single assembly!!!
I've decided to replace all the top-end gaskets. I tore off the valve cover to polish it and was surprised how brittle that gasket was. Then I realized that the last time the engine was opened up was 25 years ago! It's out of the frame and on the bench, so what the heck! As I examined the top end more closely, I could see the head gasket had been weeping in more than one spot. I just hated to do it because the bike ran flawlessly before the tear-down for this restoration. Placed my order with Parts-n-More a few moments ago.
Thanks to all who have or do respond! I'm so itching to start putting this back together!
M.W.Vachon
2014 CB1100 Deluxe
1999 Valkyrie I/S
1965 Honda S90
1976 GL1000
1975 CB400F
Offline Ted Nomura
« Reply #10 on: March 13, 2006, 02:05:22 PM »
Never reuse old head gaskets. Leaky head gaskets on early CB750 engines were common. All my CB750 suffered from this, even after careful 16,000 miles and it's such a pain to change it because you need to remove he engine first. It's hard to believe that early CB750s were more reliable than the BSA Rocket III/Triumph Trident 750s of those days but you have to give Honda a credit for maintaining strong customer service back then. They always fixed my Honda quickly without charge.
1969 Honda CB750, two 1970 CB750, two 1972 CB750K2, 1971 CB500, 1975 CB550, 1976 CB400F, 1968 CL450, 1973 CL450, 1974 CB450, 1970 1/2 SL350K1, 1971 SL350K1, 1972 SL350K2, 1972 CL350, 1972 CB350, 1983 CB1000C, 1976 Kawasaki KZ900A4, 1976 KH500A8, 1979 KZ400B, 1983 ZN1300, and so on and so on...
Offline Ted Nomura
« Reply #11 on: March 13, 2006, 02:15:15 PM »
Yes, that was a common early complaint. Honda redesigned for the CB500 Four (pre-CB550) so it doesn't have to, not to mention eliminating the dry sump feature. The best way, actually the only way, is to remove the CB750 engine from the right. Some guys even glind the front right engine frame mount down a bit to make the removal easier. I usually put a wooden block over the right side of the engine and just tip the whole bike that side to remove the engine. This prevents paint scratches on the frame. Of course the best way is to completely strip the frame and reassemble like the factory guys.
Offline lassenc
« Reply #12 on: March 14, 2006, 02:12:12 AM »
A "stop-leak" additive worked out for me, no leaks anymore :)
Stopped use it now, and still no leaks :)
How exactly do you teach abstinence though?
It's like beating a dead cow, it's fun, but it doens't really get you anywhere.
Offline mwvachon
« Reply #13 on: March 16, 2006, 09:44:36 AM »
Well,
Questions have been answered! I pulled the head off the engine anyway. Since #1 - This is just about a full-on restoration project - and B: The only way to service the 750 SOHC is to pull it from the frame, I decided to go the safe route and check out everything that could be an issue here.
After pulling the head and closely inspecting I was able to determine that the head gasket did indeed have a few spots that were allowing a tiny bit of oil to escape. I also determined that the rubber disc seals that reside under the two cam holders were also weeping oil.
The bores have been inspected and measured (all in the 2.403" and under range and still round!) and the cylinder walls still have their cross-hatch markings (not sure if it has ever been honed since new).
Head appears to be straight and other than deposits on the valve faces, the valves appear to be fine. Took the head to the local machine shop anyway - just to verify all this. Plus they will install new valve seals and clean the entire assembly so I can refinish it.
Also replacing the clutch friction plates while I'm at it. They were within spec, but they are original (34 yrs old!), so thought it would be worth doing it now.
While waiting for parts, occupying time by polishing the valve cover and case covers... Now it will end up being both pretty & mechanically sound! Thanks to all for contributing to this thread...
M.W.Vachon
2014 CB1100 Deluxe
1999 Valkyrie I/S
1965 Honda S90
1976 GL1000
1975 CB400F
