Author Topic: Weber carb set-up  (Read 174555 times)
Offline Tintop
Re: Weber carb set-up
« Reply #950 on: April 19, 2019, 12:31:01 PM »
They are the original Italian Jobs..
+1 40DCOE's.  As mentioned previously, if they are even close to correct jetting and the accel pumps are working all it should take is 2 / 3 twists of the throttle to prime it for start.  The only time I ever had to use a choke with webers was when it was -3 in the winter.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #951 on: April 19, 2019, 01:09:37 PM »
Oh yes Welcome to the club.
 Crank wrist twice  is like the secret handshake.
Offline Tintop
« Reply #952 on: April 19, 2019, 05:09:37 PM »
 ;D ;D ;D ;D  Worked for bikes, cars, sidecar, never tried it on a boat. :)
77 CB550 Cafe build
« Reply #953 on: April 21, 2019, 09:23:18 PM »
 I hear the new ones are from Spain and should be cleaned before use due to grit left from machining.
Offline Tintop
« Reply #954 on: April 22, 2019, 05:20:17 AM »
They have been making the carbs in Spain since the mid 90's, 1st time I've heard that.
77 CB550 Cafe build
« Reply #955 on: May 12, 2019, 06:28:30 PM »
 Just some online BS, possibly one guy's opinion. Maybe worth a check just in case. Same as with the Demon carbs when they moved production to Mexico.
« Last Edit: May 13, 2019, 10:14:48 AM by Don R »
Offline Tintop
« Reply #956 on: May 14, 2019, 11:03:59 AM »
All that said I always flush them out with carb cleaner before assembly, some of these NOS carbs have been sitting on shelves for a long time.  The NOS Italian made one I used on the sidecar was made in the 70's, so was pushing 50 when 1st un-boxed & used. :)
77 CB550 Cafe build
« Reply #957 on: May 15, 2019, 07:05:28 PM »
Anyone ever run Dellortos on a 4 cyl ?
 I have at least 2 pairs.. time to start using up my stock.
 Of course manifolds need to be made.
 I could use baseline jetting for Dell,s... if anyone has it.
Offline Tintop
« Reply #958 on: May 15, 2019, 07:21:29 PM »
I had a set on a Toyota TC 2TG 1600 (bored/stroked to 2L).  Tuning was very similar for the Weber 40 DCOE's later used on the same engine.
77 CB550 Cafe build
Offline sohc boy
« Reply #959 on: May 17, 2019, 03:55:46 AM »
Have two sets of Dellorto's , 40mm DHLA ,and manifolds, sold as kit from Lynx ,never ran em, will look see what jets an vent's
i live by the voice inside my head
Offline Tintop
« Reply #960 on: May 17, 2019, 05:12:47 AM »
I'm not sure at this point,(been a very long time ;)), but seems to me that Webers, Dellortos, and Solex (?) all work on the same manifolds.
77 CB550 Cafe build
« Reply #961 on: May 17, 2019, 06:00:33 PM »
Webers and Dellortos for sure the same,  more carbs than manifolds out there.
 I stil, have 3 different ones.
Offline sohc boy
« Reply #962 on: May 18, 2019, 02:43:02 PM »
dont know what size engine these were on ,main 125 ,air 200, emulsion 7772.5
« Reply #963 on: May 18, 2019, 07:49:22 PM »
 Thanks I wil, try to dig them out and see what they have, plus I have some extra jets.
« Reply #964 on: September 07, 2019, 07:32:23 PM »
 I'm hoping to mount mine soon, someone on FB was asking for help and I posted a link to this.
Offline corky
« Reply #965 on: September 16, 2019, 08:08:10 AM »
hey guys,
This is an awesome thread....there is an amazing amount of information in here.
Does anyone have some jetting info on running webers on a larger motor, more in the 1000cc area?  I see a lot of good info for 750-836 motors!
Thanks,
Daniel
Offline Tintop
« Reply #966 on: September 16, 2019, 08:59:55 AM »
hey guys,
Thanks,
Daniel
Your idle jets should be very similar, if not the same.  Surprising how little these change vs engine size.  As for mains / airs / emulsion tubes, I'd start out with what has been posted here before for the larger engines, maybe go 1 step richer on the mains.  Also be aware if you dyno tune that cracking the throttle will engage the accel pump and throw the readings off, slow roll-on works better.
77 CB550 Cafe build
« Reply #967 on: September 17, 2019, 07:40:43 PM »
Daniel, a basic rule-of-thumb is 28mm chokes for 736cc, 30mm chokes for 836cc, and 32mm chokes for 1000cc. A 1000cc bike will run just fine with 28mm chokes, but may not make as much HP on the dyno as it would with 32mm chokes. The main jet size is related to the choke size, the engine displacement, the emulsion tubes, auxiliary chokes etc, but in the end, Webers are somewhat forgiving. What parts do you have on hand? ;)
« Reply #968 on: October 04, 2020, 10:22:10 AM »
Just a reminder of how hot these can look...
« Last Edit: October 04, 2020, 10:24:50 AM by 754 »
Offline Tom
« Reply #969 on: March 23, 2021, 02:49:30 AM »
These are still available new in Melbourne Oz a bit expensive but available.
https://www.lynxauto.com.au/honda-motorcycle-cb-750-2-x-weber-dcoe-manifold.html
'59 T120.,'70 T120R Had one new.,'69 CB750 Oz Sandy Ruby Red.,'69 CB750 Oz Sandy Blue Green.,'70 CB750 K0 Candy Gold.,'71 CB750 K1 Valley Green I bought new.,'71 CB750 K1 Candy Garnet Brown.,'76 Rickman Honda CR750 R.C. Eng Cobra Powered. Two CB750 Choppers a Amen Saviour and a a Santee rigid arm Softail. A ‘72 Z1 Jaffa, and lotsa fun Honda Monkey bikes.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #970 on: March 23, 2021, 06:00:41 PM »
I’ve got an MPD under my bed. 250 bones shipped in the mainland
« Reply #971 on: September 22, 2021, 01:12:13 PM »
 Without re-reading the entire thread is there any specific throttle cable that works with Webers and a center pull linkage? I think it's going to be just a short pull cable and cut to fit. Right? 400F bars and a k2 right control.
Offline Tintop
« Reply #972 on: September 22, 2021, 03:47:51 PM »
I had Motion Pro make 1 for the sidecar's single cable twist to Weber set-up.
77 CB550 Cafe build
« Reply #973 on: September 22, 2021, 04:04:39 PM »
You can cut down a stock cable..
« Reply #974 on: September 22, 2021, 06:54:59 PM »
 That's what I was hoping Frank. That K2 had some seriously tall bars on it so that cable has no use to me at all unless I cut it.
