Author Topic: Better late than never!  (Read 8973 times)
Offline jkidd01
Re: Better late than never!
« Reply #25 on: May 18, 2010, 03:41:16 PM »
That is one really nice bike.
Where did you get those indicator lights?
1982 CB650SC Nighthawk
1981 CB650C
« Reply #26 on: May 18, 2010, 04:35:29 PM »
The scupture is awesome! Really like your indictor lights too.
Offline Grnrngr
« Reply #27 on: May 18, 2010, 06:05:50 PM »
Wow...amazing looking bike, totally awesome "related" sculpture, and a complete 2 page start to finish build thread. Not bad for a new guy!!! Welcome to the club!!
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline fastbroshi
  • Puppet
« Reply #28 on: May 19, 2010, 06:47:30 PM »
I have a spare triple at the house, I can measure it when I get home.
Just call me Timmaaaaay!!!
Offline Little_Horse
    • My cafe build
« Reply #29 on: May 19, 2010, 09:46:02 PM »
well since you can create things in autocad perfectly you can measure the exact distance with a caliper from the inside edge of each fork tube at the very top of your forks, then measure the exact diameter of the top fork tube. You can then plug that info into autocad, then find the centers and you can create a perfect model of your brace, by using the centers you found. It is much more accurate in this instance then trying to measure centers perfectly.
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
Offline fastbroshi
  • Puppet
« Reply #30 on: May 19, 2010, 11:08:12 PM »
  I thought you could just measure from the near side of one circle to the far side of the other and that would be your center?  At least that's the way I was taught at a bodyshop I used to help out at.  Didn't think you'd need autocad or anything like that.
Offline MickeyX
« Reply #31 on: May 20, 2010, 01:30:04 AM »
I'm not sure how you are doing that with your caliper, fastbroshi. I'll have to go look at some and figure that out. I would have done it like cornandp suggested so I had the center distance and the diameter of the forks to CAD. Maybe I'm not getting what you mean. I'm not a machinist or anything, just an amateur. Hmmmmm.... off to check out calipers since I'm apparently wide awake tonight. Ya never know what you're going to learn around here.
    • My cafe build
« Reply #32 on: May 20, 2010, 07:16:44 AM »
so then find something you can use as a spacer that won't compress at all and put it in between so you can accurately measure, just dont forget to add the spacer length back into your measurement. If it is any consolation you can build a 5 part brace where the centers measurement can be + or - .02 to .05 like mine.
    • My cafe build
« Reply #33 on: May 20, 2010, 08:22:57 PM »
nicely done those vaypors are nice units.
Offline fastbroshi
  • Puppet
« Reply #34 on: May 21, 2010, 12:23:55 AM »
   I'll see if I can explain.  My favorite crayons don't work over the internet so bear with me.  Given our two identical circles, or the holes in the triple for our fork tubes, they'll have the exact same diameter, 35mm on a CB550.  They'd have the exact same radii too, or the orange measurement, which is 17.5mm.
   We can measure from center to center(the pink line) or, from the same point on each circles outside diameter.  This is the blue line.  Both measurements would be identical.  Which one you use just depends on your measurement tool and the easiest way you can take your measurements.  Hope I didn't mess that up.
   And I forgot to measure that yesterday morning, sorry.  It's like 5 AM when I get off.  I'll try and remember to do it if you still need it.
« Last Edit: May 21, 2010, 12:57:00 AM by fastbroshi »
Offline eurban
« Reply #35 on: May 21, 2010, 05:09:11 AM »
How is the quality on the fiberglass gas tank from Legendary?  Truly ready for paint?  Any obvious issues with today's gasoline?  THANKS!
    • My cafe build
« Reply #36 on: May 21, 2010, 07:19:32 AM »
you can measure just above your fender, there shouldn't be anything in the way there.
Offline MickeyX
« Reply #37 on: May 21, 2010, 09:59:54 AM »
I understood where you were measuring from. I guess what I was meaning was... are you putting a caliper firmly on the outside of one fork and then eyeballing it to line up to the inside for a measurement on the other fork?
Offline fastbroshi
  • Puppet
« Reply #38 on: May 21, 2010, 12:26:25 PM »
Mickey, I'm not sure if you're talking to me but if so, that's a no.  I've just got a spare triple I put the measuring tape to.  It's exactly 5.75" or 146.05mm between the fork legs' centers.
    • My cafe build
« Reply #39 on: May 21, 2010, 01:37:14 PM »
well if you do a 3 part brace that has half of the collars on the bridge it has to be absolutely perfect or it will bind the forks. Just fyi.
Offline MickeyX
« Reply #40 on: May 21, 2010, 02:32:49 PM »
I dunno about eyeballing it with a standard tape measure, considering it's forks. I have no idea what tolerances you would need for this kind of stuff though. I am watching what you guys say about this stuff because I am considering something like this for Kit's CL350.  :)
