Author Topic: forged TRW 64mm piston to wall specs?  (Read 14436 times)
Re: forged TRW 64mm piston to wall specs?
« Reply #25 on: May 21, 2010, 09:36:37 PM »
 When you go really big on sleeves, its easy to get sealing /leaking problems.
  some things you can do;
 Rough out the bores in the cylinder , then weld any holes apearing, I think MEC showed this being done. Then finish bore the somewhat sealed cylinders.
 Rough bore, clean, then goop it up with epoxy, then finish bore.,
 That may help, another thing that may have gone wrong is.. if ANY sleeves got switched after finish boring & honing..
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #26 on: May 22, 2010, 12:50:46 PM »
these sleeves can't be mixed up, as the flanges overlap the stud and oil holes and had to be milled around them. i numbered them anyway.
i'll report back on the impregnation sealing when the engine is back together, but they only charged me $75 (including shipping i believe) to run the thing through the process twice. In my opinion, it's well worth the money to go this route rather than welding, etc. i will still be gooping the bottom "o-ring" area, as i didn't end up having o-ring lands machined after all. guess i'll have to trust the goop and the impregnation sealing.
in good news, Soos has saved the day with some 64.75mm pistons which are in the mail already. he believes they will be close to a direct drop in, so hopefully i'll be back on track next week.
if the bore will now be 736cc, what do i call this thing to not confuse it with a stock bore cb750?  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #27 on: May 22, 2010, 01:31:20 PM »
 a straight up 750..
 BIG Bore 500...
« Reply #28 on: May 22, 2010, 06:08:30 PM »
How about "Hand Grenade"? Ha ha, just kidding Paul, how thin are those sleeves going to be if you bore them another 3/4 of 1mm? My 750 sleeves after boring to 65mm for an 836cc kit were only 2.5mm thick, are yours still the same OD, or were they thinned externally as well as machining the cylinder block? Cheers, Terry. ;D
Offline paulages
  • 1976 cb735
« Reply #29 on: May 22, 2010, 07:15:41 PM »
no, the O.D. wasn't changed, except that the tapered part at the bottom was brought up to the right spot for the 650 block. if your 65mm pistons left the sleeves 2.5mm thick, i reckon my 64.75mm pistons will leave the sleeves 2.75mm thick.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #30 on: May 22, 2010, 07:30:59 PM »
No worries, that should be fine Paul. Cheers, Terry. ;D
« Reply #31 on: May 22, 2010, 10:45:02 PM »
[quote author=paulages link=topic=70922.msg791283#msg791283 date=1274580941
[/quote]
Slight miss-calculation there paul; if the bore is .25mm less, then that will mean .125mm more sleeve thickness: 2.625mm.
Offline paulages
  • 1976 cb735
« Reply #32 on: May 22, 2010, 11:03:31 PM »
[/quote]
Yes, true.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #33 on: May 25, 2010, 03:32:18 PM »
this worked out great... Soos and i are trading pistons, his 64.75mm for my 64mm. the new pistons are at the machine shop and the boring should be done tomorrow. setting them up at .0012" P/W clearance. one more part of the saga complete...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Big Jay
    • CBRzone
« Reply #34 on: May 26, 2010, 09:37:46 PM »
Sounds right to me.  Did you call and talk to Pat?
Offline paulages
  • 1976 cb735
« Reply #35 on: May 27, 2010, 12:41:12 AM »
yes. thanks for the advice!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
