Author Topic: why do PO's mess things up so bad???what's the worst you've had  (Read 3609 times)
Offline turninwheels
So, I'm disassembeling the front hub cuz for some reason the PO thought it would be cool to put the disk and the speedo housing on the same side...not only will the caliper not fit but it messes with the whole ergonomics...
"high powered suicide machine."
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: why do PO's mess things up so bad???what's the worst you've had
« Reply #1 on: May 19, 2010, 06:18:03 PM »
I found a nail in the fuse box instead of a 20 amp fuse. I guess the fuse kept blowing, so he "fixed" it with a nail. The nail didn't blow, but the fuse box and wiring harness suffered a meltdown.
..............Paul
Offline Alan F.
« Reply #2 on: May 19, 2010, 06:54:29 PM »
I'm building mine with lots of torx head screws, I'll probably never sell it so I'll piss off anyone stupid enough to steal it.
Offline mgbgt89
« Reply #3 on: May 19, 2010, 06:57:04 PM »
I would much rather have torx screws than phillips.
Offline Ayrity
« Reply #4 on: May 19, 2010, 07:13:23 PM »
+1000
1976 Honda CB550k
Offline Alan F.
« Reply #5 on: May 19, 2010, 07:14:48 PM »
Thanks, besides I can grab a few from work whenever i need them...thankfully they're all metric. They all have a gold iridited finish that seems to resist rust too.
A
Offline spill
\CB750F2
Words do not explain thoughts very well . . . but a picture might help!
Offline fastbroshi
  • Puppet
« Reply #7 on: May 19, 2010, 07:24:23 PM »
that's funny
Just call me Timmaaaaay!!!
Offline 333
  • Time for change
« Reply #8 on: May 19, 2010, 07:31:44 PM »
How about a Next Owner story.  Sold a cherry '80 CB125S (10 years old, 1000 miles).  I was working at a dealer at the time.  3 days after I sold it, It showed up with a "get running" order.  It seems that the carb had been disassembled and reassembled with parts in upside down.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Lenny55
« Reply #9 on: May 19, 2010, 07:49:16 PM »
I just pulled the rear wheel off the bike for the first time yesterday.  One of the POs had the brake rod running up over the swingarm, and the lever it connects to was pointing skyward.  The paint had rubbed off where it was touching of course.  In my quest to set things right on the bike I put everything back to the way it should be.  It was a pain to get the lever off, and a pain to get it back on.  The bolt that clamps the lever to the brake assembly was chewed to hell and wouldn't thread back in at all.  I ran a tap through the lever and replaced the hex head bolt and solved the problem.
Not to mention the "roundish" lock nuts on the chain tensioner bolts.  I mean, If you don't have the proper wrench, just leave the f*@&*ng thing alone!  Unless you're stuck on the side of the road of course.
There have been many other things as well, mostly fastener related.  I guess I'm lucky in some ways, stripped fasters are relatively easy to deal with for the most part, at least nothing on my bike has had saws, torches, welders, nails, etc applied to it.  At least not that I know of......... ???
Rant over, Lenny.
'73 CB500
Rlint
« Reply #10 on: May 19, 2010, 08:28:58 PM »
I ordered an air filter for 74 550, got it, found out that the airbox has been entirely replaced with a later 550F airbox.  It's not really that they screwed it up at all, it's just a pain in the ass, but it's not that hard to rig up my air filter to fit into the airbox properly.
Offline fastbroshi
  • Puppet
« Reply #11 on: May 19, 2010, 08:29:01 PM »
  Those adjuster bolts are always rounded...
Weird, I thought they were identical except for the lids.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #12 on: May 19, 2010, 08:39:31 PM »
I've been lucky.  Of my two CBs, one was a barn find that probably had been sitting for years (no reason for the PO to mess with it if he thought it was junk), and the other had just over 10k miles (too "new" to really need much fiddling with).  The low-mile bike did have some work done to it though.  I don't know exactly what, but the phillips screws were replaced with SHCS (usually a sign of tinkering), and the fins on the jugs are bent and broke in a way that suggests they were taken off (with a hammer  >:().  So I guess I just contradicted myself - the PO of the low mile bike chipped the fins.  But other than that it seems fairly well taken care of.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Rlint
« Reply #13 on: May 19, 2010, 08:47:28 PM »
From what I've read, they started routing the crankcase breather to the airbox in 1975, so before that, I guess the airbox was different.  The Clymer manual I have shows a difference, but I can't remember if it's between K and F specifically, or just between years.
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #14 on: May 19, 2010, 09:16:58 PM »
I found two screws and a cigarette in my 1998 FZR's gas tank
Its hard to be wrong when you know nothing!
Rlint
« Reply #15 on: May 19, 2010, 09:48:39 PM »
you should try switching to a light cigarette, supposedly gives you a little bit more in the midrange...
Offline bender01
« Reply #16 on: May 19, 2010, 10:23:32 PM »
My 78 750f PO soldered a rear turn signal bulb to get a connection. Im still figuring it out.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline MaaseyRacer
    • Fuelist
« Reply #17 on: May 20, 2010, 09:50:04 AM »
The previous owner used an orbital sander in a piss poor attempt to resurface the head.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline Badger 5
    • Gallery
« Reply #18 on: May 20, 2010, 10:51:51 AM »
I had a dime in my master cylinder and a kitchen sponge for an air filter when i got my 550.
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
Offline gmonkey
« Reply #19 on: May 20, 2010, 12:09:20 PM »
Lost the spring and washer that hold the oil filter in place and I think kept the bike at the bottom of a pool for the 3 months before I bought it, but otherwise not bad.
When I had my cbr600, when my battery died one fall, I parked the bike and took the engine out for the winter to check the valves and such.  Winter goes by, summer goes by, I move apartments and finally have to get around to putting the engine back in.  Throw it back together, ride the bike to the new apartment, park it again.  6 months go by, I move again.  Move the bike by truck but decide to sell it.  Get the bike running again, ride it around a bit.  Guy from work comes by to check it out.  Says the throttle feels weird.  Turns out I reversed the throttle cables so it was backwards.  Felt fine to me... :)
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Offline Patrick
« Reply #20 on: May 20, 2010, 12:58:49 PM »
The shifter on one of my 750s acted weird, so I pulled the left side cover. Apparently PO had lost or broken part of the shifter mechanism so he fashioned a replacement from one of those double hole locking tab washers that hold the sprocket nuts on. It worked. I can't decide is he was a fool or an evil genius.
I got a K0 with a reputedly fresh big bore top end rebuild. PO couldn't get it started so I got it cheap.  It would not fire and the compression was bad so I tore down the top end.  From the pistons it appeared that only two of the cylinders had ever fired, and those only very briefly. I discovered that PO had used a standard 61mm head gasket with an 810 big bore. I saved the head gasket as the fire rings were never compressed. I did not reuse it.
I've got eight vintage bikes. I could go on and on....
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline CycleRanger
  • No comment about being an
Re: why do PO's mess things up so bad??? What's the worst you've had?
« Reply #21 on: May 20, 2010, 02:17:59 PM »
We already have this thread.   ;)
http://forums.sohc4.net/index.php?topic=61742.0
Offline mixstup
« Reply #22 on: May 20, 2010, 05:32:28 PM »
I picked up an old stinker non runner 750 Supersport for parts...the cam tower bolts had been sheared off by some ham fisted ape and replaced with Robertson #10 self tapping screws???? The motor was hand jammed (brush painted!) all over with silver hammerite...the shame!! ;D
Offline MJL
  • Don't listen to me, I'm no
« Reply #23 on: May 20, 2010, 05:59:49 PM »
I found this on a Kawasaki.
Offline cameron
« Reply #24 on: May 20, 2010, 08:27:45 PM »
I got mine from the original owner.. and what HE did was this:
Ordered every touring option possible, I think.
It is a '76 CB550.. it had a giant matching orange windjammer 3, highway bars, a his an hers seat, and a giant luggage rack, and a backrest..
Ugly as sin, never since have seen anything like it.
A little like this:
http://image62.webshots.com/462/4/49/33/2556449330038621900sKJaLl_ph.jpg
plus this: http://www.vintagecycleprints.com/images/e76ea11.JPG
only all crammed onto a 550.
I guess he really wanted a Goldwing.
1976 CB550F
