Author Topic: What To Tape Off When Painting A CB750 Engine  (Read 4240 times)
Offline heyjones
« on: May 31, 2010, 06:41:44 PM »
I'm getting ready to paint my cylinder and head, just wanted to make sure that I have everything taped off that I need to tape off. The valves have been lapped already, so I really want to make sure I do this right. Here are some photos...
Any suggestions?
1976 CB750K
My Build Thread
Offline Old Scrambler
Re: What To Tape Off When Painting A CB750 Engine
« Reply #1 on: May 31, 2010, 06:54:28 PM »
Good start........suggest putting studs or plugs in threaded openings.........cover the plastic with paper......it will drip overspray onto the painted surface........if you have a spare valve cover.....use it.........the paint will come off of the cover with a simple spray and wipe with paint remover.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline heyjones
« Reply #2 on: May 31, 2010, 07:17:01 PM »
Thanks for the info, I'll grab something to plug those threads with. The part I'm most concerned with are where the spark plugs go... do I need to plug these openings?
1976 CB750K
My Build Thread
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #3 on: May 31, 2010, 09:03:39 PM »
ok, just got yer email. the finned areas go all the way through in some spots. I masked mine just like yours with gorilla tape for blasting and when I was done it was full of alum oxide(blast media).
it got in through those passages. so when I painted it I stuffed rags in the spark pockets. and there is another area in the middle that goes all the way through to the valve side. you won't have much to worry about it because it prob won't get that far in. I would mask the spots where the exhaust screws go in, the whole flat spot around the screw hole, otherwise it just gets scraped off, but it's no biggie.
plastic is always a problem cuz paint drys on it fast, then when it moves it crumbles off onto your paint job. paper or just tape like you did is the best.
tips: you don't want to build up too much paint on the head. but to get in all the small areas a lot of people end up going too far and getting runs, etc. what you need to do is; do one light coat(the tack coat)- just mist from about 12 inches all over. this is a very layered surface so you need to do your passes aiming up slightly, then down slightly, then to the left a lil, then right the same. they have to be light or you will get runs. if you go all in one direction you will have holidays.
so 1st it's a light coat not complete coverage, only about 10-20%, so you still see gray.
let that dry for 10-15 min. then do what will become a complete coat. from about 6 inches. to avoid runs, get the deep areas first, all the little weird crap that you have to get from different angles. do the obvious broad strokes last. try for uniform coverage.
you can stop there, or wait 10-15 min and do one more coat, but if you're last coat is a light coat, some paints will flash a bit. so a full coat to finish is best.
everytime you stop for more than 10 mins turn the can upside down and spray til it's clear, and when you start again start your initial pass off the piece, so if it spits out a boog it's on the wall, not on yer paint job.
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #4 on: May 31, 2010, 09:24:45 PM »
just noticed yer last post, you def need to mask the openings, clean rag strips pushed in tight and made level at the 1st or 2nd fin down.
and the part I'm talking about that goes all the way through is on the 1st pic in the middle of the finned area where the cross piece fin is. I masked mine from the top of the cylinder head where it opens to, I put rag strips in the holes. and masked the valve guide openings just in case. the holes I'm talkin about in yours is blocked by the cam towers, assuming it's all still together. it is, right? but like I said I don't think paint will travel too far to be a problem, just take care in that spot.
gimme a call if you need help.
Offline Spanner 1
« Reply #5 on: May 31, 2010, 09:30:49 PM »
The WHOLE livingroom.
Offline heyjones
« Reply #6 on: May 31, 2010, 09:31:39 PM »
Zzzing!
1976 CB750K
My Build Thread
Offline heyjones
« Reply #7 on: June 01, 2010, 05:24:24 PM »
Thanks for all the info, took the stuff out today and slapped some paint on... all in all pretty pleased with how they turned out. I went with the Duplicolor Gloss Black Engine Enamel (DE1613).
1976 CB750K
My Build Thread
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #8 on: June 02, 2010, 09:30:53 AM »
nice work!
Offline heyjones
« Reply #9 on: June 02, 2010, 09:32:49 AM »
Thanks, it bled a bit under the valve cover... should I sand that off or will that have any affect on how well the gasket seals up?
1976 CB750K
My Build Thread
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #10 on: June 02, 2010, 09:47:12 AM »
I would use some solvent to get it off. sanding is prob not necessary, and could mess with your mating surfaces meeting up well. denatured alky or paint thinner. brake fluid takes paint off, but can ruin your paint job if your not careful. denatured is the safest for you and the piece. it's just alcohol, that has been altered so bums don't drink it. just wipe it on with a rag, then scrub it off. if you get any on the outside it might make the paint look hazy if it's not cured complete. it'll take the sheen off, just be careful.
the engine should look pretty good underneath this:
going in the mail today.
Offline heyjones
« Reply #11 on: June 02, 2010, 09:51:33 AM »
Anything would look good under that!
1976 CB750K
My Build Thread
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #12 on: June 02, 2010, 10:01:37 AM »
now the paint goes all the way to the black edges of the decal, the clear part around it is covered. the decal is actually under the base because I redid it when I noticed the clear part of the decals wasn't blending.
so it looks super seamless, like it is suspended in petrified root beer.
only thing that bugs me, I'm way too picky, is the decal has some white edges in a few spots, from the printing of it. I doubt anyone else will notice.
I gotta get back to working, I'm gettin sucked in to the sohc4-non-working-vortex.
