Author Topic: 1978 F2 Advice  (Read 729 times)
jus750
1978 F2 Advice
« on: June 03, 2010, 05:35:22 AM »
Hi Im just about to start building my 750 F2 after many months of tracking down parts and have a couple of questions
1st purchased a Dyna s ignition with matching coils and a universal 8.8mm lead kit with silver plated copper wires ( Im sure they  do not have resistor's fitted) the lead kit brand is Accel. Can I run the standard NGK D8EA Plugs ?  engine is F2 with 900DOHC pistons, think capacity will be around the 836 mark ? Does this seam right ?
2nd. rebuilt forks, What fork oil is suitable, I know there are heaps of threads on this, but is castrol grade 10 fork oil ok for general use
3rd. Im half way through getting some new tyres. The wheels are standard comstar 19.1.85 front and 18.2.15 rear. The tyre fitted on the back currently is a 130 90/18. It seems a bit fat on the rim, should it be a 120 90/18 ?. The front tyre is a 90 90/19 Is this standard ?
Any help would be apreciated, Im just trying to get everything sorted to make the build as painless as posible
