Author Topic: Not charging changed about everything!!!!!!  (Read 970 times)
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« on: February 08, 2006, 04:53:12 AM »
 Hey all got a 1973 750 K was riding last summer and had a short  in under left sidecover well shut bike off pulled cover and moved wire that was causing the short (was wire for the dyna s I hadnt put back in yet) now fired her back up and rode home then a day or so later realized it wasnt chargeing I replaced all the components in there no change oh one wire a ground was burnt so fixed that and it is working as a ground again  then changed the allternater no change   think there is a certain wire down line burnt off oh I am color blind so its like trial an error  grrrrrr   please help  Craig  up here in Maine  seven fifty four ever
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline Lumbee
    • My pics...
Re: Not charging changed about everything!!!!!!
« Reply #1 on: February 08, 2006, 07:42:11 AM »
...have you hooked a multimeter to the battery while its running, and reved it up?  Does the voltage change at all from when the motor is off/idling/reving?  I'm just wondering if it is not charge at all, or just just a weak charge.  No charge at all would indicate a catastrophic wiring problem somewhere, as opposed to a weak charge may be a bad/weak stator.
"I'm not a welder, but I play one on HondaChopper.com"
« Reply #2 on: February 08, 2006, 07:46:03 AM »
Alternators on these rarely fail, i would say never but somebody will shout at me!, Its almost certainly a wiring fault with possibly a regulator fault and lastly a rectifier fault. If you are colour blind you will need some knowledgeable help
