Author Topic: 550K with MAC4-1, no baffle....too loud?  (Read 1631 times)
traveler
« on: June 15, 2010, 07:16:29 AM »
Quick question, please.
Anyone on here ever heard or rode a 550 with a MAC 4-1 without a baffle?
I want a Yosh pipe, but since they are unobtainable, I'm toying with the idea of using a MAC 4-1 with the canister chopped off....in effect making a Yoshi style exhaust.  Just need to know if the noise is prohibitive.
As far as back pressure, that can be handled easy enough, by drilling a hole in the bottom of the pipe and inserting a washer with some threads welded on the end.  Once in the pipe...the threads stick through the hole, and you can turn/adjust the washer to add backpressure as needed......an old Harley drag pipe trick that really works! ;)
Anyhow, just want to know about the volume of the exhaust.
This setup, especially if it is ceramic coated could really be the "cats pajamas". ;D
Thanks in advance.
~Joe
Re: 550K with MAC4-1, no baffle....too loud?
« Reply #1 on: June 15, 2010, 09:24:29 AM »
Yes. It is too loud.  Unless, you are actually AT the race track.
Offline IndyFour
« Reply #2 on: June 15, 2010, 11:14:49 AM »
When a friend of mine at work was looking to buy his CB500, it had an older 4-1 exhaust much like the MAC on it with no baffle.  Since he did not yet have his license at the time, I test rode it for him.  It sounded cool at idle....but was deafening at highway speed.  Unless you are going to use the bike for the track, I'd use the baffle...unless you want to lose your hearing....or your neighbors to hate your guts.  :)
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline edbikerii
    • Gallery
« Reply #3 on: June 15, 2010, 11:42:30 AM »
no baffle is just utterly ridiculous.  Yes, I've tried it.  It rattles windows, sets off car alarms, and attracts lots of unwanted police attention.
MAC 4->1 sounds good enough with the baffle.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: June 15, 2010, 12:32:44 PM »
Loads of fun for a bit, but is rediculous.
If you've never tried it, give it a go, it's a hoot.
I repacked mine with about a quarter of the glass and struck a nice balance of ridability and
racetrack rip when you tach it over 7k
« Last Edit: June 15, 2010, 12:36:40 PM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline edbikerii
    • Gallery
« Reply #5 on: June 16, 2010, 12:15:06 PM »
Interesting, but my MAC 4->1 came with no glass at all.  Admittedly, I think the package arrived in fairly bad shape when I bought it, so it may have been opened and the glass removed.  Perhaps my jetting advice is not 100% applicable for MAC 4->1s, after all.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline mgbgt89
« Reply #6 on: June 16, 2010, 01:14:47 PM »
I occasionally run my cb650 mac with no baffle. It's fun for a day or so, then it gets really old. It sounds awesome, so boomy down low, and above 7K it is an absolutely deafening scream. I was told you could hear me coming almost 2 miles away. I would like to modify my baffle to kinda strike a balance between the two.
Offline edbikerii
    • Gallery
« Reply #7 on: June 17, 2010, 05:55:38 AM »
Did your MAC come with glass, or just a steel baffling mechanism?
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline mgbgt89
« Reply #8 on: June 17, 2010, 09:17:08 AM »
Just a steel baffle. No glass.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #9 on: August 08, 2010, 10:25:40 AM »
I know this post has kinda run its course but I too tried chopping a custom 4 into 1 with no baffle and my 750 was SO LOUD! It was insanely loud, I have a neighbor with a Harley and he poked his head out to see what all the ruckus was about. I'm going to make a steel baffle similar to what I have on my EG6 to shut it up. I just didn't know the old girl could sound like that.  :)
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline Zaipai
    • My Home page
« Reply #10 on: August 08, 2010, 11:03:59 AM »
Joe,
I have not personally heard it, however Spikey has, I believe he has done it before and told me it was way too loud. That said, why not try it.. Your baffle should come out by unscrewing the bolt in the back, I know mine works that way and I believe we have the same exhaust. I can not get mine all the way out with out a puller tho, yours however is new and should come out easy enough, and go back in easy as well.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline domer
« Reply #11 on: August 08, 2010, 11:09:39 PM »
i lost what little baffle i had in my kerker, on my 500... i couldnt ride it. i got pulled over twice on my way back to look for it.  and i think ill never hear that tone again...
Offline KeithB
« Reply #12 on: August 09, 2010, 04:50:13 AM »
My MAC  (CB 750 bike)came with the mechanical baffle and sounded really bad. Bought the MAC "glass packed" baffle and it really improved the tone.
You can also pack in some fiber glass around the mechanical baffle and it should help.
Nanahan Man
