Author Topic: first time 2 stroke top end rebuild  (Read 1854 times)
Offline westondc
  • Wes Mantooth
« on: June 24, 2010, 05:32:12 PM »
Ive got a 2 cycle engine that needs repair and i'm taking on the project myself. I have no experience with 2 stroke motors. The oem piston lost a small chunk but the cylinder walls look good. The bike has an auto oiler and the piston is 72mm stock. So, im planning on buying a weisco piston kit but not sure if i need to bore it .5mm over or just have it honed and keep the stock 72mm. Do i wait to buy the piston kit and have a shop check to see if it needs to be bored? Also to i trust the auto oiler or premix? This should be an interesting firt time project.
« Last Edit: June 24, 2010, 05:37:02 PM by westondc »
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
Re: first time 2 stroke top end rebuild
« Reply #1 on: June 25, 2010, 09:26:53 AM »
what are you working on? most dirt bike cylinders have a nikasil coating that cannot be honed or punched out. you have to send them out to the factory so they can recoat. if you sleeve it, you can get 3-4 top ends out of a sleeve. otherwise, leave it and as is if the cylinder looks good
i say premix, just in case. that's probably just preference. better safe than sorry, though.
Offline westondc
  • Wes Mantooth
« Reply #2 on: June 26, 2010, 10:05:17 AM »
well i might be getting a bit head of myself here. well its out of a 250cc polaris atv, not really a "bike" but an engine all the same. i pulled the engine out and got the head off to inspect the piston. the cylender is good, no scoring, but the bottom of the piston is shattered. the bottom half of the engine is full of the broken piston parts  :( so it looks like i will need to split the cases and do a full rebuild.... not what i had expected to do. so i'm wondering how to split the cases now. the shop manual says to heat them up and use a crankcase puller. i need some pointers here. should i use this http://cgi.ebay.com/ebaymotors/Crankcase-Splitter-Separator-Tool-Motorcycle-ATV-Crank-/300392246412?cmd=ViewItem&pt=Motors_Automotive_Tools&hash=item45f0c5ec8c
1972 Honda CB500k1
1971 Honda CB350k3
Offline westondc
  • Wes Mantooth
« Reply #3 on: June 26, 2010, 10:10:14 AM »
here's a pic of my poor little engine
1972 Honda CB500k1
1971 Honda CB350k3
