Author Topic: Best place to get CR Carbs for my 550  (Read 1255 times)
traveler
« on: July 10, 2010, 11:51:29 AM »
Where is ther best place to get CR carbs for my 550?
Thinking about making the leap to CR.....not happy at all with my stock PD's. >:(
Preferrably get them from a place that will set them up for me.
Any help/advice, please?
~Joe
Re: Best place to get CR Carbs for my 550
« Reply #1 on: July 10, 2010, 12:02:45 PM »
I'm not sure you'll get a bolt on set of carbs without some fiddling.  CR's on a stocker? Check for 26mm from Dynoman.
Are you not making headway with your PD's?
traveler
« Reply #2 on: July 10, 2010, 12:10:02 PM »
nope.  same problem i had with the "old" carb last night. :(  Then today, all 4 carbs are pouring fuel out the throats....so I took them apart, ran fuel out the carbs, re-installed the floats, and same problem.....so I'm done with them. >:(  I do longer want to play with them.  I'm done.
I shot "kos" an e-mail.....perhaps you are right, 26's are probably the best route.
Thanks for the info about Dynoman....I shot them an e-mail as well!
~Joe
« Last Edit: July 10, 2010, 12:19:19 PM by traveler »
traveler
« Reply #3 on: July 10, 2010, 02:56:36 PM »
Got a reply from Dynoman:
Said they would work, but would be more carb than I need until wound up and at WOT.....but he had sold alot to guys running them on basically stock 550's.  And that, if I liked to keep her wound up, it would work great, just not as much low end power as stock carbs.
So, what about using some 26 CR's?
« Last Edit: July 10, 2010, 03:01:19 PM by traveler »
traveler
« Reply #4 on: July 10, 2010, 06:30:08 PM »
« Reply #5 on: July 10, 2010, 06:53:54 PM »
Well will they work...of course. Stock are 22mm so changing to 26mm will certainly change characteristics. You'll need to run pods because the airbox won't fit the CR's.
I would be curious to hear what anyone that has a set on a stock engine has to say too.
traveler
« Reply #6 on: July 10, 2010, 06:55:40 PM »
yeah, the guy at Dynoman said guys are running 29's on stock 550's and they are making extra power at WOT, but at lower RPM's power is suffering.
I asked him about 26's...haven't heard back yet. :-\
I'll use the factory velocity stacks
~Joe
traveler
« Reply #7 on: July 10, 2010, 09:36:21 PM »
traveler
« Reply #8 on: July 11, 2010, 09:03:36 PM »
please?
