Author Topic: bike started now it wont....  (Read 810 times)
Offline beks82
« on: July 24, 2010, 12:06:09 PM »
Hey guys, I have 76 750F and after putting it all back together bc the PO had it disassembled I got it to start last night.  Bike wouldn't idle and fell flat on its face whenever throttle was closed....still a great night bc i finally got it started.  Anyhow this morning tried to start it and it would not turn over.  battery was charging all night and the fuel was turned off during the night.  So my question is what possibly could have changed since last night?  I tried adjusting the idle after frosty helped me last night to try to get it to idle but no success.  i read that the stock idle set point was halfway between seated and loose, anybody has any verification on this?  Other than maybe the idle point being wrong im out of ideas  ???
Offline Spanner 1
Re: bike started now it wont....
« Reply #1 on: July 24, 2010, 12:15:52 PM »
I wish there was a 'standardised' use for common terms used to describe stuff!
by the term ' wont turn over' do you mean A. when the starter button is pressed, nothing happens or B., when the button is pressed, the motor spins but does not fire/start ( wrong usage, but common! ).. ?? If A. then look at the battery connections for shiny and the battery ground connection to the frame, also tap the solenoid while pressing the start buttom... if B. then different answer!
Offline beks82
« Reply #2 on: July 24, 2010, 02:12:07 PM »
good point, i was wrong, i meant it keeps cranking when i push the button and nothing else happens....
Offline vern401
« Reply #3 on: July 24, 2010, 03:49:58 PM »
Ok lets trouble shoot it then
1. Check the spark on all cylendars.
2. Make sure you are getting gas into the carbs. open the drains to make sure gas is in the bowls.
3. Spray some carb cleaner or WD-40 onto the carbs and try cranking it to see if it runs with it.
Let us know what you get
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline beks82
« Reply #4 on: July 24, 2010, 05:58:38 PM »
thanks guys, after charging the battery it did fire back up.  I'm guessing that I drained the battery trying to start it and it just made things worse.  now to the idle problem... :(
Offline tgtint
« Reply #5 on: July 24, 2010, 06:01:57 PM »
Not that I really know much yet, I'm about a month ahead of you but a big issue I ran into was vacuum leaks around the carb boots.  Make sure they are nice and tight, those old Honda clamps go to crap.  West Marine has nice stainless clamps that are near identical
1973 CB750
Offline vern401
« Reply #6 on: July 24, 2010, 06:16:22 PM »
Warm the engine up and then start setting the idle. The hot idle is different than the cold idle.
Make sure all pipes are getting hot.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline Spanner 1
« Reply #7 on: July 24, 2010, 09:52:29 PM »
I hope lots of future posters see this ( not likely ) !..... " Wont turn over = no crankshaft turning "...... not 'won't fire/run.. thank you all  ???
Offline beks82
« Reply #8 on: July 24, 2010, 10:47:22 PM »
would not having exhaust or headers installed affect back pressure enough to mess with the idle of the bike?
Offline wrenchmuch
« Reply #9 on: July 25, 2010, 08:05:20 AM »
Yes . You need exhaust and air filter in place before you can set up carbs .
Run through all the tune up points : valve clearance ,timing , good plugs , ect . Carbs are the last thing to set up . There is a link to manual downloads at the top of the forum page this post is on . Follow the tune up list in the manual . If you still have problems then we can start to troubleshoot the problem .
Mike
« Last Edit: July 25, 2010, 08:12:52 AM by wrenchmuch »
CB750K1
CB750K4
