Author Topic: Wiring Harness: Keep it? Scrap it? or replace some parts?  (Read 721 times)
Offline olc101
  • CR750 Junkie!!!!
I am in the process of reinstalling my original wiring harness. When I purchased the bike from the previous owner all the electrics were working except for the brake light. Should I get a new one to save myself some headaches in the future? Or should I replace the components attached to it? The PO sprayed all the electrics under the cover black so I really don't know whats what yet ???. Im guessing starter solenoid, fuse hub etc etc. If I go this route what compnents should I replace?
I have the entire harness laid out on the table.  Ill post some pics this afternoon.
1973 CB750
Offline knowsnothing
Re: Wiring Harness: Keep it? Scrap it? or replace some parts?
« Reply #1 on: July 29, 2010, 12:31:26 PM »
The type and year of bike might help  :D
1978 CB750k Blue - for sale
Offline olc101
  • CR750 Junkie!!!!
« Reply #2 on: July 29, 2010, 12:33:46 PM »
CB750 K3.
1973 CB750
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #3 on: July 29, 2010, 05:31:25 PM »
Put some clothes on.
What's your intention for the bike? If you don't care if it's black no one else will. Just check for cuts and clean up all the connections really good. Some new wire harnesses are running a couple hundred bucks.
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: July 29, 2010, 06:02:50 PM »
I replaced mine for like 85us. K4
I was doing a total resto, so you can't
Stick  a Nasty harness back on right??
(ye olD resto snowball)
Kept the old one for spare connectors
Etc for my hack projects.
Definatley check your fuse box.
Take it off and look at the back,
Mine was green, caused problems Even with the
New harness.... Good luck
« Last Edit: July 29, 2010, 06:06:15 PM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
