Author Topic: cheap top end rebuild  (Read 1369 times)
gsusinka
« on: February 27, 2006, 06:22:53 PM »
  Hello all.  My cam chain sounds like poo, so I am considering a "refreshed" top end.  This is a '77 F2 with 40K on her .  I had it apart a few years back to replace weeping oil seals and i reassembled it without replacing anything except gaskets/seals.  I know I need a new chain and associated tensioner devices, but what else do I NEED to do wihilst I'm in there - I DO NOT need an 836 kit, titanium valve retainers, hot cam, ported heads, strenghened towers, etc etc etc.  (maybe someday)   Do I NEED new rings/honing, a rebore?  Do I need to mess with the head at all?  I don't have a lot of dough, just want a lovely running stock engine.  Thanks in advance for your advice!   G
Offline cb650
Re: cheap top end rebuild
« Reply #1 on: February 28, 2006, 04:03:34 AM »
Rings/hone and gaskets is ok.  Before honing check the cyl and make sure they are not too worn.
Generally look everything over for anything suspicious.
              Terry
« Reply #2 on: February 28, 2006, 04:33:26 AM »
I'm sure the valve guides are shot....especially the exhaust side.
Offline superchode
« Reply #3 on: February 28, 2006, 06:19:07 AM »
yeah, exahaust valve guide slop is likely. may want to check the valve seals as well.
