Author Topic: cylinder head cover tap  (Read 807 times)
Offline OLDHEAD
« on: October 06, 2010, 10:12:35 PM »
i need to tap 5 of the 6mm  holes in the cylinder head cover 1/4-20 is what iam going with
sinve they are striped so question do i have to remove the cylinder head cover? and also the availability of the lenghths arent there. theres 2" -1 3/4 -1 1/2 for 50mm-45 and 40mm
you guys thing they are long enough?
a huh
Offline OLDHEAD
Re: cylinder head cover tap
« Reply #1 on: October 06, 2010, 10:15:26 PM »
actually it looks there longer maybe with the washer it will fit
a huh
« Reply #2 on: October 06, 2010, 11:12:18 PM »
Tap the stripped 6mm with 1/4-28; it's a better fit than 1/4-20. After running the tap all the way in, switch to a "bottoming" tap, to take full advantage of the depth of the threads in the hole. Tip: to make a bottoming tap out of a standard tap, grind the end down until there are only one or two tapered threads on the end.
(and please change your avatar! You're creeping me out... If I want to see a half-naked, ugly, old bald guy, I can always look in the bathroom mirror ;))
« Last Edit: October 06, 2010, 11:20:00 PM by scottly »
Offline OLDHEAD
« Reply #3 on: October 07, 2010, 09:34:33 AM »
thanks for the tip  and the compliments
a huh
