Author Topic: 74 550 semi cafe rebuild  (Read 15686 times)
Offline Tintop
Re: 74 550 semi cafe rebuild
« Reply #75 on: January 09, 2011, 05:54:45 PM »
Great news that its up and running.  Nothing like hearing it running for the 1st time.
well it;s not the first time for it running but the first time since i tore it down
and you didn't even need those left over bolts. ;D ;D ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline cafe550
  • 74 cb550four
« Reply #76 on: January 09, 2011, 07:04:45 PM »
there is a few of those around  :D
I HAVE THE SOHC4 SICKNESS!!!
Offline Tintop
« Reply #77 on: January 09, 2011, 08:24:25 PM »
 :D :D :D :D    just proves Hondas are over engineered. ;) :)
77 CB550 Cafe build
Offline cafe550
  • 74 cb550four
« Reply #78 on: January 10, 2011, 04:39:46 PM »
true that!
Offline cafe550
  • 74 cb550four
« Reply #79 on: January 16, 2011, 06:39:30 PM »
well got my tank cleaned out as good as its going to get cleaned the piss out of my petcock and put new gaskets and o-rings in it installed tach cable and throttle cable
waiting for new to me bar controls in the mail...i really need to start taking pics again but really it doesn't look much different yet  ;D
Offline cafe550
  • 74 cb550four
« Reply #80 on: January 29, 2011, 07:48:43 PM »
still working on some wiring but here is a few new pic
Offline Tintop
« Reply #81 on: January 29, 2011, 09:16:25 PM »
That's coming along very nicely, but shouldn't you be putting the knobby on it for the snow. ;) :)
77 CB550 Cafe build
Offline Kong
« Reply #82 on: January 30, 2011, 06:43:48 AM »
I'm going to try to save you some grief in the not too distant future.  Your paint job is going to fail unless you do something to correct it soon.  It is good that you can't ride the bike right now.  Get the tank off the bike and dump all of the gas out of it and then let it air out.  Take the cap off of it and leave it off until you get the paint fixed.
The problem you've got is that the painter did not mask the top of the fuel fill.  Notice in the photos that paper was stuffed in the hole (and maybe the inside of the hole was masked) but that the top of the fill spout is painted.  What is going to happen is that fuel is going to get under that paint and start lifting it starting at the top of the cap and then moving down and out.  That top should have been masked off and left in bare metal.  The actual paint should have begun right on the shoulder on the outboard side of the rim at the point where the cap gasket ceases to make contact.  The point is that the cap gasket should only touch bare metal.  You painter (or you) can repair this by sanding only the very top of the fill spout to shiney metal right out to the edge and then taking some clear epoxy (5-minute epoxy will work) on the tip of your finger and applying it over the sanded edge of the paint.  If you don't do it you're only a couple of months away from a paint failure.
On Edit:  I just wanted to add, this is a real easy (and cheap) fix now, but once it starts to bubble up it gets a lot harder (and much more expensive) to make sure it doesn't spread.  All it takes is the fumes in the tank to get it started too, and that's why the advice to empty the tank and take the cap off as soon as possible even if you can't get around to fixing it until later.
« Last Edit: January 30, 2011, 08:19:18 AM by Kong »
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline cafe550
  • 74 cb550four
« Reply #83 on: January 30, 2011, 08:22:29 AM »
thanks for the advice
Offline cafe550
  • 74 cb550four
« Reply #84 on: February 06, 2011, 02:50:17 PM »
Offline Tintop
« Reply #85 on: February 06, 2011, 05:22:41 PM »
The tins look really good on the bike.  Nice to have it started and running, isn't it. :)  Thanks for the video.
77 CB550 Cafe build
Offline cafe550
  • 74 cb550four
« Reply #86 on: February 07, 2011, 07:23:21 PM »
thanks all i need are a rear tire seat cover and a shift shaft seal and she is done
« Reply #87 on: February 16, 2011, 08:43:19 PM »
Oh no, they are really never done!  Looks nice.
Offline Tintop
« Reply #88 on: February 17, 2011, 03:02:00 PM »
+1  Consider this phase one. ;D
77 CB550 Cafe build
Offline Jt550
  • Is more then just a F-in
  • What have I gotten myself into...... Gotta Love It
« Reply #89 on: February 18, 2011, 02:41:02 AM »
What technique did you use to clean the cover?  It looks quite nice when polished.
Harry O
It's nots fast/simple, but makes your bike look great. Click >>> http://www.ehow.com/how_4491972_polish-aluminum-mirror-finish.html
Or take the part off the enigine, clean it with dish soap, then use a cheap polishing wheel with polishing compound.... Or if your really lazy get a hand held one and work on it for a week...
It's not a quick process, but a bench buffing wheel really helps speed things up... Just my 2 cents.....
Tyler Durden: You're not your job. You're not how much money you have in the bank. You're not the car you drive. You're not the contents of your wallet. You're not your f*<king khakis. You're the all-singing, all-dancing crap of the world.
-78 CB550k with a BIG #$%* Eating Grin-
