Author Topic: winterizing 5th wheel  (Read 974 times)
Offline tramp
« on: November 14, 2010, 05:37:16 AM »
need to winterize my 5th wheel that i know little about
any idea's for a novice to do it properly?
1974 750k
Offline pidaster
Re: winterizing 5th wheel
« Reply #1 on: November 14, 2010, 07:19:34 AM »
You can blow the waterlines out with an air compressor and hope you got it all or do it the right way.
I use a hand held, drill powered water pump like this, http://www.amazon.com/Drill-Powered-Water-Pump-Garden/dp/B003EB6YHA. I hook the output up to the camper and the input is connected to a short hose dropped into a gallon of winterizer fluid. While I run the pump and assistant flushes the toilet until you see winterizer come out, then the shower, then sinks, outdoor shower, and continue until all water lines are done. I am sure to cycle some through the hot water heater. I also drain the heater after I'm done.
Then in the spring just hook it back up to water and flush it all out.
'76 CB750K
'82 CB450SC
'06 Vulcan 900
'98 Kawasaki Police 1000
'73 CB350 twin
« Reply #2 on: November 14, 2010, 07:23:51 AM »
Goes w/o sayin', drain the water holding tanks, including the black water.
I've also poured anti-freeze down the drains [in the boat].
