Author Topic: Carb spitting  (Read 2930 times)
Offline Japbikemike
  • Race Bannon
Carb spitting
« on: March 15, 2006, 03:52:07 PM »
Step 1, search for topic...
#4 carb on my 78 cb750f3 is spitting/spraying gas out the carb intake when given throttle.  It was leaking out of the intake rubber till I removed the air box.  So, stuck float?  Foreign object in around the needle seat?
Gas comes out after I guess the bowl is filled and drains out of the carb even when sitting.
Update:  1st tapped on carb bowl & body while running (bigger hammer always better) then blew an obstruction out of the hose coming off the bottom of the bowl.  Did not have any leaks....
I figure as soon as I reconnect the airbox and get things together it will leak again.  Any bets?
« Last Edit: March 15, 2006, 04:43:53 PM by Japbikemike »
"Whats my favorite bike?  The one I'm on Pal, the one I'm on."---Tom Dobson
Offline mrblasty
  • Expertly
Re: Carb spitting
« Reply #1 on: March 15, 2006, 11:15:32 PM »
Sounds like a sticky or stuck float needle, and I agree it will probably leak once you install the air box.
Good luck.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline KB02
Re: Carb spitting
« Reply #2 on: March 16, 2006, 05:27:24 AM »
While you have the air box off, drop the bowl off of that carb and check out the floats. Could be either a stuck or sticky float or obstructed needle valve. You can check them both while it is on the bike. Careful, though, gravity will be working against you if you take anything off.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline dusterdude
Re: Carb spitting
« Reply #3 on: March 16, 2006, 07:33:37 AM »
if its spitting,its a lean spit.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Japbikemike
  • Race Bannon
Re: Carb spitting
« Reply #4 on: March 16, 2006, 03:55:11 PM »
I took the bike out for a couple of miles between rain showers this afternoon.  No leaks, I'm betting it was an obstructed needle.  Put a new UNI filter in and had no performance issues.  Now to get a new shield for my cafe fairing and I'll be back to pre-dump status.
As for dusterdude's quote, kind of reminded me of the rain here in Oregon.
