Author Topic: Going to make some more badges - tank or sidecover - something different.  (Read 2755 times)
Offline greenjeans
  • 1972 CB750K2
I'm going to start making some more engraved badges.
engraved plastic......  Found some material that is 1/8" thick so they will be "beefier" than the last versions.
From the manufacturer:  "Metalgraph plus is the first metallic engraving laminate engineered for
exterior use and formulated for exceptional corrosion resistance and UV stability.  Its integrated hardcoat and subsurface brush finish
provides superior protection and is moisture and fingerprint resistant."
This material is also heat bendable - meaning, with some heat you can mold it slightly to fit the contour of your tank or side covers better.
I'll have the material in within the week.    Brushed stainless color.
Here's what they'll look like:
I'll be able to do 500, 550, 650, 750 badges - nobody will be left out.
check the for sale & service offered page if interested.    I'll have something up there shortly.
« Last Edit: January 18, 2012, 12:52:07 PM by greenjeans »
Offline singedebile
Re: Going to make some more badges - tank or sidecover - something different.
« Reply #1 on: November 29, 2010, 12:57:58 PM »
..dont forget the super sport, i might be interested
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
bollingball
« Reply #2 on: November 29, 2010, 01:05:33 PM »
I will definitely take two for the 750 How much?
Offline jneuf
« Reply #3 on: November 29, 2010, 01:14:08 PM »
Definitely looking forward to this...
'75 CB400f
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: November 30, 2010, 04:50:02 AM »
$25 for 2 emblems - 1 left, 1 right.
I can add SS after the 750 on the top line for all you supersport guys.
If anyone is interested, just PM me and I'll get all the contact info etc.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: November 30, 2010, 01:15:32 PM »
Sounds fantastic. You should team up with frankenbike and make your emblems fit his sidecovers or vice versa of course.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Grnrngr
« Reply #6 on: November 30, 2010, 01:33:00 PM »
They look perfect for the side covers....would you use these on the tank also? or do you have a larger version or a more "traditional" tank badge?  maybe a better question is..what size are they? Looks like they may be larger then the "gold diamond" on my 72...will they fit the inset on the older covers? I can bondo in the "750Four" part...
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline singedebile
« Reply #7 on: November 30, 2010, 01:39:34 PM »
yeah, if you could do
    550f
super sport
also what is the approximate dimensions of it?  ...if its larger it may stick out a bit from the edges of the side cover?
Offline greenjeans
  • 1972 CB750K2
« Reply #8 on: November 30, 2010, 02:30:01 PM »
The current dimensions are 3.184" x 2.681"      That size is kinda limited due to the tooling I have at my disposal.  I can go larger, but not smaller.
I originally designed it to go on the sides of my tank after I filled the emblems - at least that's where they are on my bike.
They also look good on side covers as well.   My covers are also filled so I don't know what they will or will not cover up....
The material is 1/8" thick.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
