Author Topic: Will a CB350 front (drum) hub fit a 76 CB400F?  (Read 5667 times)
Offline obrut
« on: December 17, 2010, 03:02:08 PM »
There is a drum brake front hub on my local ebay advertised as:
"Honda 1971 CB350 CB250 SL350 Front wheel hub complete with brakes and axle."
1. Does anyone know if this would this fit my CB400F front forks?
2. If yes, could it be laced into my existing front rim?
Offline csc
Re: Will a CB350 front (drum) hub fit a 76 CB400F?
« Reply #1 on: December 17, 2010, 05:54:52 PM »
Interesting question, after a cross reference check on bike bandits site its leads to some more questions..  Its shows the 71 sl350 uses the same axle as the 76 400f  but the 71 cb 350 uses a differant axle and their site didnt list the 71 cb250..   Futher info from the seller may be needed as to the Model bike it is actually is from..  Spokes will be differant for a drum hub than a dics hub..
It Aint a Sin to be Poor, Its just un handy as Hell        72 cb350F
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: December 17, 2010, 06:12:09 PM »
Out of curiousity, why would you want to put a drum brake on the 400f?..If possible you would also probably have to change the forks so that the stay bar would have a place to attach to...Larry
Offline csc
« Reply #3 on: December 17, 2010, 06:21:01 PM »
Also will require a differant brake lever perch for the brake cable..
Offline Kevin400F
« Reply #4 on: December 17, 2010, 06:26:11 PM »
Do it.
Offline obrut
« Reply #5 on: December 17, 2010, 09:19:50 PM »
Hmm, didn't think about the stay bar.  Main reason for changing is cosmetic - simplifiying the look (including ditching the m/c).  Also, the current disc setup (even after rebuilding, new pads etc) sucks.  Lastly, the bike isn't going to see the track.
Offline Kevin400F
« Reply #6 on: December 17, 2010, 11:30:02 PM »
The stay bar bolts to the same hole as the caliper bracket.
Offline camelman
  • Man... Myth... Legend
« Reply #7 on: December 18, 2010, 12:49:35 AM »
You could stick with your current setup (much lighter rotating mass), and still clean up the handlebars by mounting a remote, cable-actuated master cylinder.
http://www.fabkevin.com/Remote%20Master.htm
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Kong
« Reply #8 on: December 18, 2010, 04:26:35 AM »
If you think the disk brake sucks wait until you try to bring it down five times hard with that drum brake.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #9 on: December 18, 2010, 07:46:54 AM »
Sounds like a huge step backwards.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
  • Be careful you might get a
« Reply #10 on: December 18, 2010, 08:06:27 AM »
Camelman
I am going to convert to a set up like this someday.
Offline Bodi
« Reply #11 on: December 18, 2010, 08:56:55 AM »
I've ridden for 40+ years. I can't remember any time I had to "bring it down hard" five times in a row - except when riding silly on bendy roads and, yes, with drum brakes I had to adapt my riding to the brakes' state. This is hardly a life or death matter. True panic stops with a crash imminent should the brakes not be as usual are very rare. Every rider has to adjust the braking point relative to the bike's brakes and tires and the road condition.
The double leading shoe brakes on many midweight pre-disk bikes were very effective and could induce tire howl on the front. Frame geometry, weight distribution, and tire adhesion were incapable of stoppies so a howling or skidding (not good!) front tire on dry pavement meant any more braking power was unusable (except in reserve for when the brakes heated up).
Five hard stops from speed with drum brakes left one with drastically reduced brake power, true.
Have you tried it with stock 1970's Honda disk brakes? Five hard stops from speed leaves you with about the same feel as from 60's era DLS drums. The stainless rotor and whatever pad they used do not work well when hot.
Don't confuse the ancient stuff on our bikes with modern braking systems. SOHC4 disks and DLS drums come out about the same - pathetic - compared to current equipment.
The CB350 had a SLS drum on front, a bit over half as effective as a DLS unit. I would try to find a 305 or 450 DLS brake for use on a 400F. The 305 had 36 spokes like the 400, the 450 used 40 spokes IIRC. You will need a new front rim drilled for the drum hub diameter, lacing the original front rim to a drum hub will put unsafe stress on the spokes at the rim. The torque arm attachment should be no problem, there are a bunch of holes for the caliper mount. You may have to fabricate a new arm but that's just a steel bar with two holes.
« Reply #12 on: December 18, 2010, 10:03:18 AM »
well said
Offline Slams77
  • Naturally Aspirated
« Reply #13 on: December 18, 2010, 12:36:40 PM »
Camelman
Interesting.  Would this work with a 350/400 stock caliper?
Offline faux fiddy
  • bike in a box
« Reply #14 on: December 19, 2010, 12:19:30 AM »
You might have to convert to disc brake to run a 350f or 400f in some of the vintage classes,too.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #15 on: December 19, 2010, 08:21:06 AM »
Camelman
I'm thinking yes, as long as it's designed to work with a single disk and you have a single disk/stock set up.
Offline Kong
« Reply #16 on: December 19, 2010, 09:24:22 AM »
Well, I think you are a fool to do it, but its your choice.  I see you're from up in a place where all the ground is flat, so all you know about braking is when some idiot pulls out in front of you.  If you lived in a place with topography like I do you could find your self having to "bring it down hard" five times before you got to the bottom of a single hill, and have absolutely no brakes what so ever left when you got to the next hill.  It is not by mistake that drum brakes disappeared from even street motorcycles decades ago - but you're sure welcome to bring them back on your ride.  After all, its appearances that count - right?
1978 Honda CB550K
1977 Honda CB550K
Offline camelman
« Reply #17 on: December 19, 2010, 02:44:22 PM »
Camelman
I saw a CB built up with one of these.  I didn't get to ask how the braking was, but the bike didn't look like it had run into anything.  I'm actually considering it for a future build myself.
I actually had an early 80s Yamaha Seca that had this setup.  It came stock from the factory like that.  Dual front discs and a remote, cable-actuated master.  It was a little vague feeling, but it worked fine.
Camelman
