Author Topic: Question on replacing handle bars  (Read 3473 times)
nomad
« on: January 13, 2011, 07:10:08 AM »
When I replace my stock bars, will the replacement bars have to have the same knurls in them if I plan on using the stock clamp?  The set I'm thinking about using doesn't have the knurls.  Any safety issues or will simply tightening them down be sufficient?
Re: Question on replacing handle bars
« Reply #1 on: January 13, 2011, 07:27:46 AM »
They should be fine without knurls. Most bars don't have them. I haven't had them on my CB750 in distant memory, several different styles of bars used.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: January 13, 2011, 07:52:42 AM »
+1  The knurls were a supposed additional Honda safety factor.  Properly tightened your new bars will be fine...Larry
nomad
« Reply #3 on: January 13, 2011, 07:56:01 AM »
Thanks guys!
rhos1355
« Reply #4 on: January 13, 2011, 08:31:25 AM »
Nomad, are you threading the control wires in thru the bars or outside? The reason I ask is that I've read somewhere in the forum that only original Honda 'bars will accommodate all the electrical wires inside.
Is this true?
Offline 72 yellow
« Reply #5 on: January 13, 2011, 08:44:17 AM »
Is this true?
I replaced the bars on my 72 CB750 with a set from Bikemaster and had no problems getting the wires through.  I did have to drill the holes to feed the wires through however.  Used the old bars as a guide.
Offline Elan
    • Vital Motor Parts
« Reply #6 on: January 13, 2011, 08:48:40 AM »
I bought the cheap clubman bars off ebay, and they came with the knurls, lined up great. Wiring inside is a bit of a pain but definately possible.
76 750k
nomad
« Reply #7 on: January 13, 2011, 09:08:34 AM »
Is this true?
I'm going to do what 72 yellow did.
« Reply #8 on: January 13, 2011, 09:40:00 AM »
Is this true?
Nope, never ran across one yet that wouldn't accept the wiring internally. Clubmans being the exception and its becuase of the extreme turn/ joint, no other reason. Some still get it done anyway.
Offline 72 yellow
« Reply #9 on: January 13, 2011, 12:26:48 PM »
Is this true?
A side note. Make sure to smooth the holes when you drill them.  No sharp edges anywhere.  I made a nice radius on mine.  Nothing for the wires to hang up on, nothing to rub through and cause a short later.
nomad
« Reply #10 on: January 13, 2011, 01:17:41 PM »
Is this true?
Thanks for the heads up.
Hinomaru
« Reply #11 on: January 14, 2011, 04:57:38 AM »
You will probably be OK without the original knurls present, however should your replacement bars end up slipping in the stock clamp or you just want some peace of mind, an easy solution is to "stipple" the bars. Mark the bars so you know what area will be hidden by the clamps. Use a punch and hammer and "stipple" the bars. This is will roughen the surface and help the clamping force to stop the bars from turning. The link is from a gunsmith article, but it explains the process:
http://www.gunsandammo.com/content/punch-up-your-guns-appearance-?page=1
nomad
« Reply #12 on: January 14, 2011, 05:34:57 AM »
Another great idea!  I have a heavy duty electric engraver that might work well for this.
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #13 on: January 14, 2011, 06:09:56 AM »
When I first swapped out my bars, I had a bit of slippage.  i have thought about slightly roughing up the spots that the clamp contacts with a Dremel.  has anyone had any luck with this?
Thanks
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
