Author Topic: Float Bowl Gasket Q - '76 cb550  (Read 4806 times)
Offline xruss
« on: January 16, 2011, 03:42:21 PM »
I've pulled the carbs off my 1976 cb550k.  I purchased carb rebuild kits and have a question on a gasket.  There is a round black gasket in the kit that I assume is the float bowl gasket.  The float bowl themselves are shaped much like home plate on a baseball diamond.  Is this the correct gasket for this, or should there be a gasket that is already formed like home plate?  I didn't want to start scraping out that old gasket without making sure the big o-ring gasket in the kit will fit into some kind of channel on the bowl itself.  I'm accustomed to rebuild kits for outboard motors, which have always been pre-formed gaskets, so I'm just second looking for some assurance.  Thanks.
1976 cb550k
Re: Float Bowl Gasket Q - '76 cb550
« Reply #1 on: January 16, 2011, 04:04:08 PM »
A lot of kits use a round gasket rather than a fitted one for the float bowl gasket. That is what I suspect you are looking at. If it is they are a bit tricky to hold in place.
Offline Bluto
    • company website
« Reply #2 on: January 16, 2011, 04:33:58 PM »
Yep....that's it.  My kit had them as well.  It was a Bit#h gettin em to stay put.  If i recall it was like a 4-5 beer deal.
Cheers
76 550K bought brand new...mothballed for 30 years... and still running great
81 XR 80
82 XR 200
« Reply #3 on: January 16, 2011, 04:42:32 PM »
A bit of contact cement in the groove  will hold them in place.
Offline BAchvytrk
« Reply #4 on: January 16, 2011, 06:21:08 PM »
i made a set for a  cb550 i was working on for a guy. went to napa and got some fel pro gasket material, the blue stuff, and about an hour later with the exacto knife, had four nice gaskets that worked great.
71 FLH
74 Ironhead
1965 305
1971 SL350
1974 750k
1975 550F
1977 550K
1980 KZ440
1980 CB900F
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #5 on: January 16, 2011, 06:21:57 PM »
I had the same issue as well. Tried the dab of glue at first, which ended up causing a leak. Next time I tried a tiny dab of grease under the gasket on the 5 "points" to hold it in there, just before I replaced them. Worked like a charm.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline xruss
« Reply #6 on: January 17, 2011, 08:42:26 AM »
Thanks, everyone.  I have the first carb soaking in cleaner now.  One other question...I can't figure out what the small brass replacement spring replaces in the carb.  I've pulled everything apart, consulted the manual, and just don't see the spring in the original carb to replace it with the new one.  First rebuild, so its definitely serving as a learning experience.
1976 cb550k
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #7 on: January 17, 2011, 08:49:06 AM »
I didn't have a whole kit - but there is definitely a spring in the air mixture acres on the individual carbs. I had removed the screws and nothing came out with them, had to dig around gently to pull them out.
Hope that helps...
Scott
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: January 17, 2011, 12:36:55 PM »
You're lucky those springs come with the kit. I found two missing and got lucky finding a guy that had parts carbs to pilfer. The gasket isn't as hard to install as everyone says they are. There are tabs on the bowl to keep them in place. Push the o-ring in all around the bowl. Don't chase it around, it will stretch and not fit right. I never had to use anything to hold it in place on four carbs. I used a Honda OEM gasket kit.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #9 on: January 17, 2011, 06:12:00 PM »
He was given generic round gaskets not the nicely formed Honda. A VERY thin bit of contact cement and even nail polish will hold them in place. Something that dries fast is best.
Offline xruss
« Reply #10 on: January 18, 2011, 09:23:13 AM »
Got the first one rebuilt last night.  I figured out the spring situation and got everything set.  22mm on the floats.  One and a half turns past fully seated for the air mix screw.  PIA gasket in the float bowl.  Polished up the shinny parts.  Now, number two is sitting in the carb cleaner can until this evening.  By the fourth one, I should have the hang of it and realize I somehow screwed up the first one.
1976 cb550k
Offline c(b)hris
« Reply #11 on: January 18, 2011, 12:34:15 PM »
Hey man, I had the same problem with the float bowl gaskets.  a lot of frustration for sure.  These are what I ordered.  Fit perfectly.
http://www.siriusconinc.com/search_result.php?make=&model=&part=&partno=SCI2634&x=48&y=11&search=search
Can't beat the price too :-)
And when you clean them if the gaskets stretch out just drop them in a pot of boiling water for about a minute.  They'll shrink back to exactly the right size.
75 CB550
74 CB750
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #12 on: January 18, 2011, 12:40:30 PM »
The link shows gaskets for a 350.  Did this work for a 550?  Definitely the right shape and price.
~Sophocles
Offline c(b)hris
« Reply #13 on: January 18, 2011, 12:48:27 PM »
Definitely fits my '75 550K like a glove.
75 CB550
74 CB750
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #14 on: January 18, 2011, 12:52:25 PM »
Awesome. Great link and info!
~Sophocles
