Author Topic: 76'er Build  (Read 2315 times)
Offline redhawk
76'er Build
« on: January 20, 2011, 10:47:01 AM »
Haven't  done much  real work yet,  just  scabbing things  together  to  get some ideas.
Started with this:
And  playing with the new  frame,  I  probably  will stick with Honda forks (off 954)  but I  thought the  636  were  purty  gold
Still  making  decisions before I really  get rolling.
Offline Elan
    • Vital Motor Parts
Re: 76'er Build
« Reply #1 on: January 20, 2011, 12:39:37 PM »
nice. is that swingarm off a 954 too?
76 750k
Offline nickandkristy02
Re: 76'er Build
« Reply #2 on: January 20, 2011, 12:46:08 PM »
yeah please tell ;D
Offline redhawk
Re: 76'er Build
« Reply #3 on: January 20, 2011, 01:20:26 PM »
Swingarm is from 636, ,   that  will probably  stay, it  fits in the  frame  nice,  holes had to be  opened up  for  the  larger  pivot bolt and  I will likely  shave the passenger peg mounts.    Allows  for a  wider  assortment of  wheels,  I have some 954 wheels and  636 wheels,  but I  am  debating on the  wheel  ordeal.   I  kinda  want  spokes over the  sportbike wheels.   I am  debating  between red  frame or  gray.  It's all still in  planning  stages really. I'm trying to stick with what I  have  lying  around  to keep it  low buck.
Re: 76'er Build
« Reply #4 on: January 20, 2011, 01:45:56 PM »
what about the sprockets lining up?
Offline redhawk
Re: 76'er Build
« Reply #5 on: January 20, 2011, 02:43:30 PM »
Offset  sprockets, or  a  jackshaft worse  case.  Plenty of room to mount one. Based on the  measurements, I  should  be  able to  offset the  front  and  shim the  rear.
Re: 76'er Build
« Reply #6 on: January 20, 2011, 03:24:26 PM »
right on :) you may proceed
Offline tango911
Re: 76'er Build
« Reply #7 on: January 20, 2011, 03:35:48 PM »
Thank you for taking the long forks off!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Re: 76'er Build
« Reply #8 on: January 20, 2011, 04:17:56 PM »
I found with the gsxr wheels i have that the rear sprocket carrier sticks out a long way so i had some meat removed from the carrier, there is still clearance for the chain from the tyre and an offset front sprocket fixes the alignment problem....I have plenty of pics of old Honda's with wider wheels an no jackshaft.....I can post some if you like.?
Offline redhawk
Re: 76'er Build
« Reply #9 on: January 20, 2011, 04:31:54 PM »
yeah I was  thinking the  same  thing about milling the  carrier,  I'm not  looking  to  run  anything too  crazy back there,   We'll see,  If  I  run the  spokes  it  will be  a  non issue.     I'm going to  look  at  some  spoke  wheels  tomorrow  that will probably  force my decision.
Re: 76'er Build
« Reply #10 on: January 20, 2011, 06:15:40 PM »
....I have plenty I can post some if you like.?
yes please ;D
Re: 76'er Build
« Reply #11 on: January 20, 2011, 06:37:26 PM »
I don't want to hijack the post so if the op wants i will post them.... ;)
Offline redhawk
Re: 76'er Build
« Reply #12 on: January 20, 2011, 07:39:42 PM »
sure, go ahead, I'm a learner too  ;D
Re: 76'er Build
« Reply #13 on: January 20, 2011, 08:11:28 PM »
Ok guys, here you go.... ;)
Lots of nice bikes there but the yellow F bike is very nice, not too overdone.....
Re: 76'er Build
« Reply #14 on: January 21, 2011, 05:38:37 AM »
mick do you have any links by chance? ;D
Re: 76'er Build
« Reply #15 on: January 21, 2011, 06:27:42 PM »
Not on my computer at the moment, will post some links later...Mick
